Old 01-28-2014, 11:33 PM   #1
goochy
74 K5 lift
Old lift looked homemade , it was horrible !! The U bolts went in from the top , with square top U bolts , and a curved plate on the bottom ( so bolts hang down ) . My NEW 4 in kit from Rough Country came with regular U shaped U bolts , RC says the U bolts must go in from the bottom ( point UP ) . SO now I had to buy the top plates , so the new U bolts can come up from the bottom . Now the U shape will cradle the axle housing . Is this normal for different kits to mount different ways ? Any pics ?
goochy is offline   Reply With Quote
Old 01-29-2014, 08:10 AM   #2
goochy
Re: 74 K5 lift
what was stock ? plate on top of axle or bottom of axle ?
Old 01-29-2014, 09:25 AM   #3
68Timber
I know the pieces fit
68Timber's Avatar
Re: 74 K5 lift
What you had, I don't know. It doesn't sound like something manufactured to fit a 73-87, more like something lying around (or cheap) that was made to work. Maybe not, but I haven't seen a lift like that for our trucks.
Stock is axle under springs, plate on top of the springs, with u-bolts pointing up.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-29-2014, 09:38 AM   #4
goochy
Re: 74 K5 lift
Thanks ! I bought new top plates to put it back the right way !!
Old 01-29-2014, 12:16 PM   #5
68Timber
68Timber's Avatar
Re: 74 K5 lift
Looking forward to seeing it with the new shoes.
John
74 Honda Z50 build
Old 01-30-2014, 11:09 PM   #6
goochy
Re: 74 K5 lift
got all the stuff to fix it right
Old 01-31-2014, 12:26 AM   #7
eighteenninetytwo
Re: 74 K5 lift
no pics means it didn't happen
eighteenninetytwo is offline   Reply With Quote
Old 01-31-2014, 12:31 AM   #8
mud.man.rj
mud.man.rj's Avatar
Re: 74 K5 lift
Ya plates on top is normal till it gets newer like in 88 and up they switch the other way. So better take a few pics and share that K5.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 01-31-2014, 08:07 AM   #9
goochy
Re: 74 K5 lift
Old u bolts
Old 02-02-2014, 07:58 AM   #10
goochy
Re: 74 K5 lift
Messed UP !!!
Old 02-02-2014, 07:59 AM   #11
goochy
Re: 74 K5 lift
new lift is almost on . My buddy is doing most work at his shop , on lift. We are also replacing every bushing and bearing under truck !! $$$$$$$$$$$$$
Old 02-08-2014, 09:12 AM   #12
goochy
Re: 74 K5 lift
so is a 12 bolt stock in the rear of a 74 K5 ? We got the new leafs on rear , new plates on top , u bolts coming up from bottom , all looks good . Problem NOW is the rims recess in ?????????? The rear axle is NOT as wide as the front ? SO I now have to run spacers to make the rear match the front rims . You can look at it from the rear , and the rear tires are tucked in more than the front . Going to run spacers on the rear, to make it match the front . Is that normal ? My buddy thought a 10 bolt was stock , previous owner thinks 12 bolt was stock ?
Old 02-08-2014, 09:37 AM   #13
68Timber
68Timber's Avatar
Re: 74 K5 lift
12-bolt rears were stock up to 79-ish, 10-bolts after that. The slightly narrower rear is factory, and would be the same whether 10 or 12-bolt. You can put some spacers on to make them match. I've been looking at them all my life, so spacers, or matching track widths front and rear look funny to me and probably everyone else who is used to it.
John
74 Honda Z50 build
Old 02-08-2014, 12:14 PM   #14
goochy
Re: 74 K5 lift
Learn something every day . Thanks !! Why did Chevy make the rear slightly narrower ?
Old 02-08-2014, 04:44 PM   #15
mud.man.rj
mud.man.rj's Avatar
Re: 74 K5 lift
That is a question we would all like to know why the rear is narrower from factory, strange isn't it.
5.0 4spd std.
7" lift w 35's.
