![]() Join Date: Jan 2014
^^ drive shaft length
I have a 66 short bed thats dropped 2 inches in the rear and has a 350 Turbo tranny. Need to know the distance from the pinion shaft center (with the 3/4 inch play) to the the saddle on the rear end. I had to pull my drife shaft our for new U joints and it would not come out without sliding the axle aft... thus my dilema... I cant lower the truck and measure so its either re install everything and drop to the ground and remove the bed to measure or wag it with some help on here. Thanks in advance...
Barney |
Re: ^^ drive shaft length
Ask your driveline shop how to measure without the driveshaft in place. I think you measure from the yoke on the rear axle to the end of the transmission splined shaft. they will then know how much to add for the needed slip joint and u joint. Put it on them they will tell you what dimensions they need. Kieth
no one can tell you the exact dimension since your truck is not stock, we do not know where the motor is mounted, etc. You will have to measure it. If you cannot get to it because it is too low then jack it up and put it on jack stands so you can get under it. |
Keith thanks bro, Im going to throw it back together, pull the bed (need to work on my 20 gal tank and lines also) and upgrade the wire harness to tail lights. Just thought I might see if anyone was close to 56.5or 58 inches. Thanks again
