01-29-2014, 04:44 PM | #1 |
putting cab on frame with windshild?
can i install my windshield and then put the cab back on frame? seams it would be much easier to install W/S sitting down low and being able to work around the front. will be using my cherry-Picker to in stall the cab.
1961 chevy K10 my build is------------61K10 build |
01-29-2014, 05:23 PM | #2 |
Re: putting cab on frame with windshild?
Seems awfully risky to me. I'd hate for there to be any twisting that could cause the glass to crack. I've never done it though, so I have no backup. Just thinking...
'58 Apache |
01-30-2014, 09:16 AM | #3 |
Don't know about that but I ran heavy duty tow straps through my side windows and back over the top hooked to a chain hoist in the rafters and removed and reinstalled my cab three times with no problems!
May your life be like a roll of toilet paper... Long and useful or short and crappy!!! http://67-72chevytrucks.com/vboard/s...d.php?t=584520 |
01-30-2014, 01:03 PM | #4 |
thanks for the reply's--my method is like your straps
01-30-2014, 04:21 PM | #5 |
It's Better With Nitro
I have several times throughout my build ups. I just had to compensate the lift balance for the weight of the glass.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
01-30-2014, 07:47 PM | #6 |
A buddy of mine has a truck lift that I will be using to lift my cab. I do like your idea there 61K10.
It starts as a diamond in the rough. |
