Old 01-30-2014, 12:57 PM   #1
Branman1971
Branman1971's Avatar
New Donor Truck Today (maybe)
So I have a 61 swb with bad cancer all around the roof area and where the dash meets the glass and such and I have found a 63 LWB for a good price. Its just the frame and body, no motor or tranny but has a great inner and outer roof with drip rails, dashboard, and the body is good so what I dont use I can sell off, if I dont just swap the whole cab. I am going to see it in a little bit but before i do i wanted to ask if there was any reason why i couldnt use the 63 for parts as i heard somewhere that the 63 is different then the 60-62, i just dont remember how. Torsion bars suspension not used in 63? Maybe thats what I heard...And the width of the frame? I dont remember.
Active duty Navy CPO
1961 C10 SWB
1963 C10 LWB (donor)
1965 C10 LWB BBW
Branman1971 is offline   Reply With Quote
Old 01-30-2014, 02:26 PM   #2
66Submarine
66Submarine's Avatar
Re: New Donor Truck Today (maybe)
The '60-62 are x-frame trucks, and IIRC the cab mounts are in a different location.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 01-30-2014, 02:43 PM   #3
KTSK10
KTSK10's Avatar
My 61 has a lot of similar cancer around the windshield. I found a 62 donor to replace it with. 60-62 seems to be the magical matching years for a lot of the body. Not sure, but I think they changed the doors somewhat also. I'm still learning a lot about the trucks in that time frame. I'm still looking around to see if the hood on mine is correct. All the pics I see of 61's seem to have the hood that matches the contour of the dash. Mine doesn't have that one..... It fits just fine, but doesn't seem to be correct.
It starts as a diamond in the rough.
KTSK10 is offline   Reply With Quote
Old 01-30-2014, 03:04 PM   #4
61K10
61K10's Avatar
KTS--here is my 61 hood
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 01-30-2014, 03:20 PM   #5
Branman1971
So I am looking at this 63 right now. One noticeable difference is that they did not use the torsion bar suspension. My question is if I want to put this crossmember in my 61 could I easily install Power brakes? Or maybe even disc brakes? I know that most people use a 73 to 87 to do the disc brake conversion.
1961 C10 SWB
1965 C10 LWB BBW
Old 01-31-2014, 08:41 AM   #6
tincan1966
tincan1966's Avatar
You do not have to ditch the torsion bar FE to have power disc brakes.
tincan1966 is offline   Reply With Quote
Old 01-30-2014, 04:43 PM   #7
KTSK10
KTSK10's Avatar
That's the hood I see most on the 61's. Mine has the turn signals in the hood but is straight across.
Old 01-30-2014, 05:39 PM   #8
Clyde65
Clyde65's Avatar
Your hood is a 62-66 my friend.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-30-2014, 07:42 PM   #9
KTSK10
KTSK10's Avatar
Well Dag Nab It....... Another part to hunt down. Looks like I'll have some extra parts, for a swap meet, in the future.
Old 01-31-2014, 02:46 AM   #10
Captainfab
60-66 Nut
If you want to get away from the torsion bar front suspension and upgrade to disc brakes, I would just find a '71-'87 front suspension and use that. The '63 front suspension and crossmember could be used, but that just seems like more work than necessary.
The '60-'62 cabs will work on a '63-'72 frame, you will just have to drill the holes in the cab for the front cab mount bolts. And if you want, the cups can be moved to the new location. However then you get into the possible legal issue of having a frame and a cab with different VIN numbers.
Old 01-30-2014, 05:49 PM   #11
Branman1971
Will this 63 crossmember bolt up to my 61 frame? That is my main question cause I got the truck.
1961 C10 SWB
1965 C10 LWB BBW
Old 01-30-2014, 07:40 PM   #12
KTSK10
KTSK10's Avatar
One of the things I did to help me with the interchangeability issues is I invested in an interchange manual. You can find them on line pretty cheap. I am working with a K10 so I can't help you much with the "C" truck. The manual has been a great help, as well as some of the senior members of this site.
