Old 07-20-2003, 11:42 PM   #1
72MARIO
72MARIO's Avatar
3:08 gears how much should I get for my used pair ?
There is a guy up here (Canada) who need's my old gears (I went to 3:73's) The guy who did the work on my diff. at the shop gave me the old ones and said to keep them that they were worth saving.
What should I ask for them ? I have no Idea.
Thanks guys.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 07-21-2003, 12:00 AM   #2
stateamind
And you call that a what?
stateamind's Avatar
I remember being told in the past that when a gear set (ring and pinion) is run in a particular axle housing, it wears a certain way. So, if you remove the set and install in another housing, there is the possibility of noises or in extreme cases, maybe even breakage. I was told this by a very experience and repuitable mechanic. I have never purchased used gears because of being told this. Just thought I'd share that with you.
As for price: new set would run around 175-200 US green, so figure no more than half that.
stateamind is offline   Reply With Quote
