02-02-2014, 09:23 PM | #1 |
Engine question
My 69 gmc has a 1973 Chevelle 350 small block with heads, intake and exhaust if the 69 350 anyone know if there was a purpose to this? It's confusing to me that someone would spend the time to use all their 69 components on a 1973 unless there was a hp or torque reason
02-02-2014, 10:13 PM | #2 |
Re: Engine question
I'm sure that's probably just what they had on hand. That's what is done 99% of the time, when it comes to hot rodding
______________________ www.northeastrodrun.com |
02-03-2014, 12:22 AM | #3 |
Re: Engine question
x 2 with what was on hand . that's the way folks with limited funds stay on the road as inexpensively as possible .
This is MY rifle.There are many others like it but this one is MINE. Beware the man who only owns 1 rifle , he probably knows how to use it. |
02-03-2014, 01:29 AM | #4 |
Re: Engine question
They prob figured the '69 pre smog heads & intake were better flowing than the 73 smog heads.
02-03-2014, 02:25 AM | #5 |
Re: Engine question
Or, the original engine had a bad/cracked or something block and they found a cheap block out of the chevelle to put in and bolt on all the other parts
Austin 2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked) 2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l |
02-03-2014, 08:00 AM | #6 |
Re: Engine question
A lot of times it's easier to keep all the peripherals so that you know they will fit your chassis (ie, accessory drive bracketry, water pump and cylinder heads for attachments, etc).
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-03-2014, 08:14 AM | #7 |
Re: Engine question
What all these guys said.
If you find an all original small block engine in anything that has fitment from '55 to the '90s. Then you hit a small goldmine HAHA |
02-03-2014, 01:57 PM | #8 |
Re: Engine question
What are the date codes on the heads and block?
