02-04-2014, 12:23 PM | #1 |
FREE 1961 Short bed frame whole/parts
I have a 61 swb frame sitting in the yard. Has complete suspension. Anybody who wants it or any parts off of it can come get them. I will have the frame towed off for scrap in 2 weeks if its not gone by then. Bring tools for whatever you want, although I can help some with tools and labor. If you want the whole frame as it is, its your. Frame is straight, has the HO 52 10 bolt rear (gear unknown), and all front/rear suspension is there. Originally was a fleetside w/6cyl and 3 speed, but could be used with a stepside if desired pretty easily.
I really hate to send it to the scrap yard as the front end components are expensive for the 60-62's, and I'd like to just find a good free home for it, but either way....in two weeks it'll be gone. Take a little or take a lot, but please come take it.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 02-04-2014 at 01:05 PM. |
02-04-2014, 10:08 PM | #2 |
Re: FREE 1961 Short bed frame whole/parts
Any pictures of rear trailing arms?
02-04-2014, 11:13 PM | #3 |
does it roll? I have a truck and trailer and am only around 40 miles away. I need a swb frame for a project but never have dealt with the torsion bar front suspension. I know about the x frame brace but can a later model cross member be installed like a 78 1/2? I have a lot of left over parts and is that rear ten bolt, 1/2 ton 6 lug?
Let me know, I can PM my number and pick it up Friday. Thanks, Steve scjkovach@qaol.com |
02-05-2014, 01:35 AM | #4 |
hillbilly
Interested in frame. Pm with contact info
-1962 C-10 |
02-05-2014, 10:06 AM | #5 |
The frame has rims and tires on it, but I need the two rear tires/rims as they are off my other project. We can get the frame loaded, but I would need to take off the two rear tires/rims once its loaded. The cab and front end in the picture are not included. I will help with what labor and tools I can. I have a jack and 4 way lug, which is really about all that would be needed. Frame will roll, hasn't been moved in 3 months, but that shouldn't be an issue. I would recommend a come-a-long just as a backup to get it loaded.
easiest contact for me is email due to my work load: emt0289@yahoo.com or PM me here I can get more pics of the frame, but will take a day or two. I wont be home until after dark tonight. Picked up a 63 bbw short fleet and need the space.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 02-05-2014 at 12:10 PM. |
02-05-2014, 02:35 PM | #6 |
sounds good, I use a come along any way to load. Had 2 winches stolen off my trailer. I think have 2 6 lug wheels. Still for me, the main question is will I be able to swap a later model crossmember and suspension to the front? I have heard all sorts of horror stories about the torsion front suspension and my left over suspension parts are for later models.
If I can use a later model bolt one suspension on this frame I will "TAKE IT" and can pick it up Friday. Email me a number and I can call you. Thanks, Steve quicksilver69@aol.com |
02-05-2014, 02:57 PM | #7 |
There is a thread in the FAQ section on using a newer model crossmember on the 60-62 frames. I'll see if I can find the link.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
02-05-2014, 03:00 PM | #8 |
check out thread # 2 on this link. Using a 63-87 crossmember on a 60-62 frame
link: http://67-72chevytrucks.com/vboard/s....php?p=4450757
02-05-2014, 03:09 PM | #9 |
Kenny strong was 1st to respond, so he has 1st dibs quicksilver, but if hes not interested its yours. I tried to email you quicksilver at the email you provided and it keeps sending it back to me. I'll pm you my #.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 02-05-2014 at 05:16 PM. |
02-05-2014, 05:18 PM | #10 |
2 more pics. I took the rear driver side tire off Sunday due to a bad valve stem. Frame looks good other than surface rust and damage to one frame horn (see top mounting bolt) should be an easy fix.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 02-05-2014 at 05:25 PM. |
02-05-2014, 09:41 PM | #11 |
If quick silver can get it let him have it. I only need the trailing arm set up so I would rather see him be able to use the whole frame.
02-05-2014, 10:45 PM | #12 |
whoops, my meds must have kicked in! it's qksilver69@aol.com
I am going to check out those threads. It will probably be tomorrow before I call. I haven't seen one of the frames since the 80's didn't realize the were boxed like that, a bonus! hat looks like a good foundation for a tough 4X4 only have to box toward the front. Thanks, Steve |
02-05-2014, 10:54 PM | #13 |
If it makes it to me for some reason I really need a frame for my 60 the one I picked up for it was rotten on the back third and I hauled it off for scrap...I'm doing a frame off on a 60 bbw short fleet and need a frame real bad...62chevy302 was actually trying to help me out and was speaking for me he knows my frame issues I'm in Asheville and can make the drive
02-05-2014, 11:11 PM | #14 | |
02-06-2014, 11:14 AM | #15 |
No mines a 60 want to keep original but thanks
02-06-2014, 11:15 AM | #16 |
I had a powder coated 64 frame I just traded to try and keep correct stuff under it but thanks for that
02-06-2014, 11:50 AM | #17 |
If qksilver doesn't get the frame, its yours. Hes supposed to contact me today.
02-06-2014, 01:49 PM | #18 |
Hey if you really need a 60-62 frame go for it.......I see the 63-66 frames come up once in a while so they aren't that rare. for somebody to really need/want that year frame I will step aside..............63-10 if you have that link for the other frame cool. Email me or
Leroy the frame you have? either way let me know............... thanks, Steve qksilver69@aol.com |
02-06-2014, 02:31 PM | #19 |
OK, so Leroy-B1....looks like the frame is yours.
qksilver....i'll find the link on the 63 frame. was I believe 1-2 hours east of Fayetteville. Nice rolling frame w/tires/rims.
02-06-2014, 02:36 PM | #20 |
qksilver....look up member 62 bigwindow, hes in Mocksville nc and had the 63 frame.
02-06-2014, 09:16 PM | #21 |
COOL........i always try to gather all my major stuff before starting my reconstructions. You have jumped me a few times as have I you on craigslist!
Thx, Steve |
02-09-2014, 12:04 AM | #22 |
I am looking for the passenger side frame rail cut a few inches behind the cross member for a 60 thanks
02-09-2014, 04:57 PM | #23 |
I found one locally I will pass on this sorry just cant justify a 5 hour drive when I found one here
02-09-2014, 09:38 PM | #24 |
Should have gotten that frame instead of being nice. Just spent $200 and $80 in gas.
Thanks....................... Steve |
02-10-2014, 12:36 PM | #25 |
Its still here if you want it Steve.
