Old 02-05-2014, 12:57 AM   #1
bosephus
bosephus's Avatar
61 ho 32 to 64 12 bolt ?
Is the 64 12 bolt rear diff a " bolt in" replacement for a 61 ho 32. Panhardbar mount looks good but I was wondering if the trailing arm mounts were the same .thanks!
bosephus is offline   Reply With Quote
Old 02-05-2014, 01:31 AM   #2
Dillon Rock
Re: 61 ho 32 to 64 12 bolt ?
Do you have an Eaton Ho 32?
That's the thing about a Chevrolet, no matter how they look, whether it be a trailer queen or a good ol' used farm truck, no other truck on the road will always look that damn good wearing a Bowtie.
Dillon Rock is offline   Reply With Quote
Old 02-05-2014, 02:54 AM   #3
Captainfab
60-66 Nut
You will have to move the trailing arm mounts on the 12 bolts since the '60-'62 trailing arms are farther apart. The '61 panhard bar should work with the '64 12 bolt
Old 02-05-2014, 01:35 PM   #4
bosephus
bosephus's Avatar
Thanks captain !
Old 05-17-2015, 03:18 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
How about the length of the driveline?
Can I remove my 62 Ho32 and mount a
65 12-bolt without modifying my driveshaft?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 05-18-2015, 12:19 AM   #6
Captainfab
60-66 Nut
Having not done that swap, I do not know for sure. I can measure a 12 bolt and a HO32 at the shop tomorrow and let you know.
Old 05-18-2015, 09:01 AM   #7
bosephus
bosephus's Avatar
I still haven't swapped mine out so I can't answer your question,but that's an angle I didn't look at
Old 05-18-2015, 09:29 AM   #8
LostMy65
LostMy65's Avatar
You've had over a year! :-D
Old 05-19-2015, 12:01 AM   #9
Captainfab
60-66 Nut
Okay here's what I came up with. These measurements are not ultra precise, but are fairly close. With the truck 12 bolt, the center of the axle tube to the center of the U-joint on the pinion yoke measures 11-5/8". The Eaton HO32 measures 12-1/4" from the center of the axle tube to the center of the U-joint on the pinion yoke. So the driveshaft will technically be 5/8" too short if you swap in a truck 12 bolt, but with that small amount it may be fine. It just depends on your particular driveshaft and trans.
Old 05-19-2015, 01:40 PM   #10
LostMy65
LostMy65's Avatar
That helps a lot.
I want to go to a th350 from my sm420.
I didn't want to size my driveline to the ho32 and then have to do again when I went to the 12-bolt.
Old 09-21-2015, 07:55 PM   #11
LostMy65
LostMy65's Avatar
Now that I have a 12-bolt that I can measure, I just did some measurements of my own.
I got pretty much the same measurements as Captain.
Also, it looks like I won't have to remove the existing axle perches. The trailing arms on the 62 are far enough apart where I should be able to mount the new perches right next to the existing ones.
Old 09-21-2015, 09:17 PM   #12
OldChevy61
OldChevy61's Avatar
On my 62, the pan hard bracket had to move over in order to use the 62 bar. Or you could get and adjustable. I was paying a welder anyways so just moved mine. Not sure about the perches as we removed the 64 ones and put a set of captains new ones on. Seems like the old ones had to come off to get the same measurement as the ho32.
OldChevy61 is offline   Reply With Quote
Old 09-21-2015, 09:37 PM   #13
61ChevyPanel
Active Member
61ChevyPanel's Avatar
It was a while ago when I put a 12 bolt from a '64 in my '61 Panel. It was the same width. Did have to move & re-weld the brackets but other than that, it was fairly simple. Can't remember if I changed the pan hard. Current piece is non-adjustable about 33" long. Can't remember if I had to change U joints.
61ChevyPanel is offline   Reply With Quote
Old 10-19-2015, 03:42 PM   #14
LostMy65
LostMy65's Avatar
Do you remember if you had to resize your driveline?
I just dbl checked my 65 12-bolt and my 62 Eaton Ho32, and the 65 12-Bolt looks to be at the very most, 1 inch shorter than the 62 Ho32.
Old 10-19-2015, 09:49 PM   #15
61ChevyPanel
Active Member
It was 20 years ago but I really don't think I had to make any changes to the driveshaft. To be honest, I don't know if I did check to see if the lengths of the two rears were different. I used a straight panhard bar at 33 5/8". Haven't had any rear end issues since the swap.
Old 10-19-2015, 09:58 PM   #16
LostMy65
LostMy65's Avatar
It's neat you've had your truck so long.
Old 01-17-2016, 06:11 PM   #17
LostMy65
LostMy65's Avatar
Anyone know the Torque requirements for the axle mounting U-Bolts?
Old 01-18-2016, 03:26 PM   #18
verdell
verdell's Avatar
Just ran across this thread and wanted to share what I have. I swapped out the 1960 HO32 for a 1965 12 bolt and always thought it may have been a tad too short. It never gave me any issues so ran it for years. I recently found out I have an unpleasant vibration just over 90 mph. Checked pinion angles, tranny mounts, axles, every thing but according to a drive train specialist in this area, my driveshaft is short. This seems to be the cause of the vibration. Just an FYI...
verdell is offline   Reply With Quote
