02-07-2014, 05:49 AM | #1 |
Speedo Needle??
77 C10. I hooked up the stock gauges and speedo cable and the needle is pointing straight down. When i drive it moves to the left but it is at least 20mph off for some reason. Whats wrong and can this be fixed? Thanks.
02-07-2014, 01:57 PM | #2 |
Re: Speedo Needle??
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
02-07-2014, 06:09 PM | #3 |
Re: Speedo Needle??
No. mine doesnt bounce or skip. It climbs steady but the needle is at the 100mph mark when the truck is sitting still. The needle moves in the right direction. Dont get it?
02-07-2014, 07:04 PM | #4 |
Re: Speedo Needle??
The speedometer needle (like all the others) is a press fit onto a round shaft.
They usually fit tight enough so they don't move out of position, but it kind of sounds like that's what might have happened to yours. Has the cluster been apart recently for cleaning or other work that could have accidentally disturbed the needle position? If that's the case, and it's working normally aside from the mis-positioned needle, you can probably fix it by carefully pulling the needle straight off the shaft and carefully pressing it back on so it's pointing at zero. |
