Old 02-08-2014, 10:05 AM   #1
FlowerForwarder
Goldie coming along
Brillant work coming from www.rpm-hotrods.com
New air ride with stock arms and original bed floor height!
Heading for paint next week....more to come!
FlowerForwarder is offline   Reply With Quote
Old 02-08-2014, 10:41 AM   #2
tjabv2
Re: Goldie coming along
wow....very nice!
tjabv2 is offline   Reply With Quote
Old 02-08-2014, 10:49 AM   #3
Mathew21
Mathew21's Avatar
Love the stance, Beautiful truck.
Mathew21 is offline   Reply With Quote
Old 02-08-2014, 12:44 PM   #4
ol_skool_chevy
ol_skool_chevy's Avatar
Very nice....... Is that rear bumper low or is it just the angle.
I have been looking for those filler pieces that go between the rear bumper and the bed
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 02-08-2014, 12:51 PM   #5
FlowerForwarder
Bumper shot
Old 02-08-2014, 01:01 PM   #6
wjjeeper
wjjeeper's Avatar
Going for paint? Wth, it looks perfect as it is!
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 02-08-2014, 01:26 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
Looks perrty!
Old 02-08-2014, 02:17 PM   #8
dougf
dougf's Avatar
Agreed, I would drive the heck out of that thing, man that would be a blast to drive!
dougf is offline   Reply With Quote
Old 02-08-2014, 04:56 PM   #9
NEWFISHER
NEWFISHER's Avatar
Let's see the bed. Curious if the pumpkin is poking through? Mine touches the underside of the bed floor and pushes the boards up a little,but isn't as low as yours.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 02-08-2014, 04:57 PM   #10
NEWFISHER
NEWFISHER's Avatar
What tire size?
GOD BLESS AMERICA!
Old 02-08-2014, 05:07 PM   #11
FlowerForwarder
NewFisher- Yes, Pumpkin is up...small rectangle is cut-out, with "leather" patch over.
sorry no pic - truck is still at www.rpm-hotrods.com
Tires - BF Goodrich - from Coker
F P215-70-15
R P225-70-15
Old 02-08-2014, 09:15 PM   #12
gimmy 64
no paint needed DRIVE IT!!!!!!!!!!!!!!!!!!!!!!!
gimmy 64 is offline   Reply With Quote
Old 02-08-2014, 09:23 PM   #13
HumphreyMurdoch
HumphreyMurdoch's Avatar
I've been following the progress on Instagram, love the look of your truck now. Looking forward to seeing the finished product.
Keep us posted.
HumphreyMurdoch is offline   Reply With Quote
Old 02-08-2014, 09:46 PM   #14
ol_skool_chevy
Instagram ?
Mark with Chalk
Cut with a torch
Old 02-08-2014, 10:22 PM   #15
HumphreyMurdoch
Originally Posted by ol_skool_chevy View Post
Instagram ?
It's a social media website & app for smart phones for sharing pictures.
Old 02-08-2014, 10:30 PM   #16
blazer-k5
blazer-k5's Avatar
Nice truck man.
No trees were killed to send this note but a large number of electrons were terribly inconvenienced.
AKA. RABIDJOE... if you have to ask you prob don't want to know. Ive had my shots *dont worry*
1960 235 4SPD C30
blazer-k5 is offline   Reply With Quote
Old 02-08-2014, 10:54 PM   #17
FlowerForwarder
This is a photoshopped picture of the truck that a board member did a few months back...... Next week it should look pretty close to it!!!!
Old 02-09-2014, 09:55 AM   #18
FlowerForwarder
from a distance
Old 02-09-2014, 12:19 PM   #19
ol_skool_chevy
So.......... You running air bags Only or air bags and drop spindles and rear c notch.
also aired out are you front tires in stock inner wheel wells??
Mark with Chalk
Cut with a torch
Old 02-09-2014, 01:20 PM   #20
FlowerForwarder
- Air Bags
- Drop Spindles
- Custom Fab work from www.rpm-hotrods.com
- Power Disc Brakes
- Front Tire Size 215-70-15
- Stock Fender Wells . it will lower about a 1/2" more if removed.
- Custom C-Notch by www.rpm-hotrods.com
- Small Rectangle Opening for rear pumpkin to nest up into bed when aired out.
Old 02-09-2014, 01:33 PM   #21
mano
mano's Avatar
Originally Posted by FlowerForwarder View Post
- Air Bags
- Drop Spindles
- Power Disc Brakes
its looking good Jim.
mano is offline   Reply With Quote
Old 02-21-2014, 11:51 AM   #22
kieth
kieth's Avatar
Originally Posted by flowerforwarder View Post
- air bags
- drop spindles
- custom fab work from www.rpm-hotrods.com
- power disc brakes
- front tire size 215-70-15
- stock fender wells . It will lower about a 1/2" more if removed.
- custom c-notch by www.rpm-hotrods.com
- small rectangle opening for rear pumpkin to nest up into bed when aired out.
what mods did you do the the front end besides spindles ? Air bags of course up front and rear but did you section the crossmember or add cups to the lower control arms ??? I have a build in process and do not really want to make it layout but just sit like yours does when lowered and then raise to go down the road.....thanks kieth
kieth is offline   Reply With Quote
Old 02-21-2014, 05:24 PM   #23
FlowerForwarder
In the front we weld the flat bottom plate, then the top flat plate we notched so the bag would fit inside when deflated. We did take pictures. The fronts also drop spindled too. It sits the front flat on the ground and the tires touching the factory inners with a 215/70/15. I used the bigger Firestone bag on the front just cause it collapses down better the the AirLift bag.
In the rear we build our own weld in notch, I plate the inside rail for strength and use a 6.5" inside diameter pipe to fit the axle and u-bolts into a little better. I spent a little time with it on the rack just grinding little issues to make sure everything cleared the way I wanted it to. Has a 2" block, Airlift Bags stock locations, Rear end goes thru the bed floor (no kissing it here). But still not crazy like I'm use too. But I think we trimmed it off nicely!!!
Double switch panel, dual needle gauges, 5 gallon tank, 2- ViAirs 444s, 175 pressure switch.
Hope that helps!!!
Old 02-09-2014, 02:08 PM   #24
NEWFISHER
NEWFISHER's Avatar
Very classy.
Did you decide to white out the upper cab or just keep the white roof panel?
GOD BLESS AMERICA!
Old 02-09-2014, 02:28 PM   #25
FlowerForwarder
Originally Posted by NEWFISHER View Post
Very classy.
It's going to paint tomorrow ....White out cab, all trim with the white inlays and white letters on tailgate
