1966 tilt wheel
Anyone replaced their stock steering column with a Tilt with key and column automatic shifter from another truck????
I'm wondering is this can be put in my 66 truck do you have photos of it in your truck?
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
Re: 1966 tilt wheel
I pulled the pin on the shifter--shaved the lump, pulled the hazard switch--shaved it and can guess that if you pulled the rack, the switch etc you could shave the hump there too. Harness is an easy wire swap and in the FAQ there is a write up on the neutral safety switch relocation/modification.
Mine is in my build thread.
GOD BLESS AMERICA! |
Re: 1966 tilt wheel
I want to keep the Key on the new column...
![]() Join Date: Aug 2004
Re: 1966 tilt wheel
I had one in my 65 several years ago but changed it to a 72 tilt. Sorry I don't have any pictures though.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: 1966 tilt wheel
The column in my truck is tilt/telescopic!
#6 | |
Re: 1966 tilt wheel
here is a picture: http://kieth.smugmug.com/Trucks/66-GMC/i-wfdFZnk click on the thumbnails to see more detail: here is where we merged old and new brackets to allow use of the 91 column and wiring.... http://kieth.smugmug.com/Trucks/66-GMC/i-WSB2DjV after shortening the column we redrilled the shaft and used nylon bolts to save the collapsible steering column... http://kieth.smugmug.com/Trucks/66-GMC/i-tDRR9pW keep scrolling to see more details....Kieth hope this helped !!! ![]() ![]() |
Re: 1966 tilt wheel
thanks Keith.............time for pick and pull
I might look for a mid 70's truck column. about 1973-78. I like the key in the column
#8 | |
![]() Quote:
Kieth's write-up and pics were fantastic, weren't they? Sam |
#9 | |
Re: 1966 tilt wheel
My 91 column has the key in the column, but there is no shift indicator. You can tell which gear it is in by feel. I do not miss the indicator..... |
#10 | |
![]() Quote:
![]() Sam |
#11 | |
Re: 1966 tilt wheel
ps think back, Delmo used a emergency brake lever to shift his transmission, not any indicator there.....either |
Re: 1966 tilt wheel
I think there are some posts here about using a column out of a van--you don't have to shorten. Can't find them at the moment, though.
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
#13 | |
Re: 1966 tilt wheel
![]() Looks like it came with it! ![]()
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
Re: 1966 tilt wheel
Will a column from a 1973-1980 work without Too much hassle. I want the key and shifter on the column
