Old 02-11-2014, 02:23 PM   #1
solidaxel
solidaxel's Avatar
Pp172 & p-174 ??
Where to start to look for a lean code correction, 2003 5.3?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-11-2014, 08:25 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Pp172 & p-174 ??
clogged injectors?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-11-2014, 09:09 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Wait one is a lean code the other is rich?
Check your 02's, check that the maf isn't dirty, clear the codes, see if they come back. Clogged injectors can be a lean code cause, a stuck-open injector can cause rich. Did you clean the injectors before installing, or ever run an injector cleaner through the system?
You haven't provided much to work with homie.. Lets get some more info.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-12-2014, 09:56 AM   #4
solidaxel
solidaxel's Avatar
Well sorry !!
I did some homework and with these comments I have some areas to look at.
The injectors were cleaned and flowed at 79 ML. the tank, lines, pump, filter, regulator, are all new.
The two rails were cleaned, and the fuel pressure is at 55#. the MAF has been cleaned with MAS cleaner and the filter and connections are new and tight.
I did find a vacuum leak at the dip stick tube, which is where I found the oil leak!
When changing ex. manifolds from truck to TBSS I was not able to get the tube to fully installed in the block, so I ordered a new TBSS tube, will know today!
And two new O2 sensors from the same folks that did the wiring and re programed the computer Howell Engine Development
O K, what next ?
LS 3 4L70E
Old 02-12-2014, 11:33 AM   #5
Hart_Rod
Hart_Rod's Avatar
You really need to log you LTFTs and your STFTs (long and short term fuel trims). This will give you a better idea of where the problem is (left or right side) and how bad the problem is. You said Howell did your tune. They can get you close, but it really needs to be data logged and at least road tuned to make sure your airflow (MAF) is calibrated correctly. 95% of tune is based on the MAF calibration being correct..... I would also try clearing the code and then driving it some more. If the code were set, but then you fixed the problem (vacuum leak at dipstick), it doesn't clear immediately unless you clear it yourself. Just my .02$. Send me your tune and I will take a look at it.
Hart_Rod is offline   Reply With Quote
Old 02-13-2014, 11:37 AM   #6
68GMCCustom
Dang Rob! A few months (weeks?) with HPT and he's talking fuel trims, MAF cal's and offering to look at tunes!
just ribbing you!
Kurt -
Old 02-13-2014, 11:53 AM   #7
Hart_Rod
Hart_Rod's Avatar
just ribbing you!
, I spent a week in a Holiday in Express, .
Old 02-12-2014, 07:26 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Does it run different with the MAF unplugged, or the vac line @ FPR unplugged?
Old 02-13-2014, 11:10 PM   #9
solidaxel
solidaxel's Avatar
O K, I did notice there was a "bit" of rufness in the idle when there were both were unplugged, hooked them back up and it smothed out...........now I am going to the Holiday Inn Express!
LS 3 4L70E
Old 02-13-2014, 04:55 PM   #10
68GMCCustom
LMAO!
Help you with those injector specs any?
Kurt -
