02-11-2014, 08:14 PM | #1 |
table saw for cutting steel ?
Good idea or bad,I was thinking of using the table saw with a metal blade to cut some 14 g. Flat sheet .
02-11-2014, 08:34 PM | #2 |
Re: table saw for cutting steel ?
I use my 8" table saw to cut 16 gauge steel. I've never had a kick back like with wood.
Just go slow and let the blade do all the work. Kim |
02-11-2014, 09:12 PM | #3 |
Should work OK. let the blade do what it does best. Don,t forget your eye protection..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
02-11-2014, 09:50 PM | #4 |
and a hat or you'll be digging metal out of your scalp for a week
use a full face shield i've cut aluminum and thinner sheet metal on my table saw, never any 14ga i have a wood insert with a saw blade width cut out so the metal doesn't pull down and chatter run the blade high so that your pulling the metal down for a clean cut but what do you have to lose? (assuming you know how to run the table saw)
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
02-11-2014, 09:10 PM | #5 |
Who Me?
I thought slower blade speed was better for metal.. Table saw may be a little fast.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
02-11-2014, 09:14 PM | #6 |
I wouldn't do it. You could get savagely injured with that set-up. Get a nibbler or shears.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
02-11-2014, 09:28 PM | #7 |
How much sheet are you planning on cutting? I'd probably go for a cheap nibbler too for sheet metal, granted you have an air compressor. If you just want to make a few cuts, metal circular blade will work. Max RPM on a Dewalt blade is 6400. Table saws run well below that so, you should be fine either way.
02-12-2014, 12:27 AM | #8 |
aluminum is fine.. I don't know if i would cut steel.. or you can even cut steel... a newbian at work ruined at non ferrous diablo blade on a saw in about 30 seconds cutting steel with it.. as for metal kicking back.. it hurts like a sob.. and if it hits your hand you're getting a new scar.
PA is supposed to have a nibbler on sale now or soon for cheap so i'd probably just run that.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
02-12-2014, 12:45 AM | #9 |
Cutting or grinding non-ferrous metals with many grinding wheels and blades will clog them up. Then, they lose their ability to shed heat and explode. Use the right tool!
02-12-2014, 09:53 PM | #10 |
i would feel more safe useing a 8" abrasive wheel in a circular saw.
i clamp a guide/straight edge on the sheet as a fence and use the saw against that and have at it. go slow let it do the work. eyes an ears saftey first. if you have something besides a straight line too cut a adustable speed jig saw works ok also.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
02-13-2014, 10:54 AM | #11 |
I found some stuff on y tube,it was a little attchment for a hand grinder which made it into a little skill saw from harbour freight,most people said the small metal filings would make short life of my table saw.I don,t think the shears would work on that thick of metal.
02-13-2014, 11:42 AM | #12 | |
The metal shavings didn't seem to bother my little table saw at all and they don't bother my angle grinder either. Kim |
02-13-2014, 10:59 AM | #13 |
One foot in front of the other
You got any local machine shops that would be willing to shear it for you?
02-14-2014, 10:47 AM | #14 |
02-15-2014, 11:41 PM | #15 |
Your (or anyone's) table saw is going to have wayyyy to many RPM's for cutting steel, even with the special blade. We have a chop-saw at our shop specifically for cutting mild steel and it only turns about a thousand RPM.
That being said, I cut aluminum routinely on my table saw, but I have a special alum blade.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
02-13-2014, 09:52 PM | #16 |
clamping an angle or flat bar to the material to be cut is a good way to get a strait cut with an abrasive disk in an angle grinder. i would be a bit sketched out to run it through a table saw. ive cut 1/4' with a metal blade in a skill saw. i didnt particularly care for it.
i second the local shop with a shear. it would be a guaranteed clean strait cut. |
