02-13-2014, 11:36 AM | #1 |
WTB Oil pressure sender adapter
I need an oil pressure adapter that bolts just above the oil filter. It's the type that needs to be drilled and threaded for an oil pressure sender.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-13-2014, 08:57 PM | #2 |
Re: WTB Oil pressure sender adapter
02-13-2014, 09:05 PM | #3 |
Here's some other info with part numbers that may give you some other options/ideas
http://www.ls2.com/forums/showthread...r-on-LS-Series |
02-14-2014, 06:51 PM | #4 |
Thanks for the info. I was just hoping someone had an extra one laying around. I do somewhere, but I just can't find it!
02-24-2014, 11:31 AM | #5 |
You still need one of these? I'm sure I have some lying around.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-24-2014, 11:54 AM | #6 |
Whatya got?!
02-24-2014, 08:44 PM | #7 |
I got one of them there $28 block off plates. Id take $26.50 for it.
Seriously though, I'd do $5 shipped on it.
02-25-2014, 11:28 AM | #8 |
Thanks! Send me your paypal!
03-03-2014, 12:01 PM | #9 | |
Rob
03-03-2014, 01:19 PM | #10 |
i bought one from my local dealer came off a gto was already threaded and used the autometter 2277 adpator to mount my sensor
03-12-2014, 01:14 AM | #11 |
They are pretty easy to thread just drill a hole and a cheap tap will do the job.
I took mine off the original sender and tapped in with a t that is sold on ebay, mainly because I have an oil cooler on mine. |
03-12-2014, 09:38 PM | #12 |
Can I ask why you can't put the sender were the original sender was for the lsx?
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
03-12-2014, 10:09 PM | #13 | |
Also my coolant temp gauge I used a sender from a 86 Monte Carlo ss and cut the threads down with my lathe to fit in the passenger side of the head. Didn't want to be cutting too many wholes into the heads or using those big donkey adapters that stick out of the block. Tach is easy to run off the pcm or msd makes a tach signal adapter that clips onto the coil wire too.. I do have a block off plate too except it's not tapped yet. |
03-12-2014, 11:28 PM | #14 |
Ok cool. I m trying to get the oil pressure through my vhx gauges via the can bus
03-12-2014, 11:41 PM | #15 | |
Dakota digital gives you pretty much all the adapters you might need including the sensors you need. Only one thing I could imagine you might have is where to put the sensors. Did you find a location to put your water, oil, and vss already? |
03-13-2014, 01:38 AM | #16 |
I have all the parameters from the obd2/canbus except the oil. DD said that it won't read it. But I read somewhere that it was possible.
03-13-2014, 01:48 AM | #17 |
03-13-2014, 01:51 AM | #18 |
2011 lc9/6L80 e38 ECM
03-13-2014, 02:00 AM | #19 |
I could have swore there is a signal from the pcm on the e38.
I'll do some checking Monday with a friend of mine and find out for you. Do you know what the signal parameters are required by DD? |
03-13-2014, 08:12 AM | #20 | ||
03-13-2014, 02:08 AM | #21 |
I am not sure. As I don't have anyway to know except what the dd reads when I plugged it in. But thank you for the information it would be nice to get all the info to the Vhx gauges. I can get the mechanics and the electric parts working this communications part I am not sure about.
03-13-2014, 02:13 AM | #22 |
No problem probably Monday I'll see my friends at ProDyno of Phoenix. One of the owners has a 70 chevy with a DD dash and turbo 5.3l I'm sure he will have the answer for sure. I will get back to you then.
03-13-2014, 02:15 AM | #23 |
Thanks for the help.
03-13-2014, 01:53 PM | #24 |
I hope we can figure it out. So until than I guess I need to put the sender that came with the gauges. In combination with the stock one.
03-13-2014, 01:58 PM | #25 |
I think that's a 1/8 NPT that came with it right? Where will you put it?
