Old 02-15-2014, 04:07 PM   #1
79Betty
79Betty's Avatar
Question Crossmember Removal
On te 77 C30 frame i have it has a crossmember going between frame rails for the cab mounts. Since the ones on my k10 are bent i figured hell why not. 14 rivets and 2 gas tank straps later she's loose!! But how would i go about getting it out between the rails? Thanks in advance everyone.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 02-15-2014, 04:19 PM   #2
J Knight
J Knight's Avatar
Re: Crossmember Removal
Most likely you will have to cut it in half to get it out then weld together once installed. The frame might have to flex or bow out to make room to get it out otherwise. Just my guess with no pics.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 02-15-2014, 05:40 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
BFH to remove it.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 02-15-2014, 07:41 PM   #4
79Betty
79Betty's Avatar
That's what i was afraid of, the BFH. I won't cut it seems like that would weaken it too bad, take it wheeling good and have the weld break, bang off goes the body. No bueno... I'll try beating it more tomorrow and see what happens. If all else fails and i can't get it i'll probably get the driver side replaced. Passenger is fine... It's weird.
Old 02-15-2014, 08:27 PM   #5
mrolds88
If you have all the rivets out and a welder, why not tack a section of pipe onto a small bottle jack and use it to spread the frame a bit? Would not only help on removal, but for installation too.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 02-23-2014, 07:33 PM   #6
79Betty
79Betty's Avatar
Winner winner, bfh. I got it back in the same way too. Drilled out the holes for 7/16 bolts as they were a bit loose for my 3/8 liking. Ah well body n tank back in tomorrow!
body mounts, crossmember, removal
