02-16-2014, 08:49 AM | #1 |
How Low Can I Go??
Looking to see how much I can safely lower my 1970 step side truck by only changing the springs.
I'm not into the real low riders but would like to lower my truck a little plus level it out. What can I do safely??? |
02-16-2014, 09:24 AM | #2 |
Re: How Low Can I Go??
Based on your statement I would say a 2-4 drop using coil springs front and rear would be safe and still very usable. This would slightly lower your truck and level it out.
02-16-2014, 09:32 AM | #3 |
What would be a good combination to lower and level?
02-16-2014, 09:47 AM | #4 |
2" lower in rear puts a truck pretty much level. 3" springs in front is the max,so 3/5 drop for lowest all spring and level. 5" is also the practical lowest for rear to maintain proper travel. Yes,you can "get away" with 6" but I said practical. 2/4 is a very nice look for those not hung up on way low. It improves handling and gives a pleasant stance without screaming out,"I'm lowered!". Subtle is always cool in my book.
02-16-2014, 09:51 AM | #5 |
CAN'T FIX NOTHIN
My truck is lowered 3" front 5" rear with spring's and in the rear it pulled the rear end to one side slightly , probly could have left it alone but I put an adjustable rear trac bar in mine cause ,,, well cause that's just the way I am LOL
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
02-16-2014, 10:40 AM | #6 |
Can you still haul 5 to 6 hundred pounds in a LWB with the 3/5 drop and still have enough clearence between the axle and the frame without a C notch?
02-16-2014, 01:07 PM | #7 | |
CAN'T FIX NOTHIN
No !
02-16-2014, 01:33 PM | #8 | |
70+ ( Old Skool Club )
So in your opinion a 2 1/2 Drop Spindle up front with a 4 inch drop spring would level a long box out nicely and give it that subtle look that I too really like. Would you need an adjustable track bar with a set up like that?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-16-2014, 01:42 PM | #9 |
I'm going to bag the back on my truck. This allows me to haul a trailer, carry a load, and set the stance where I like, when I like, including when I'm loaded. I'm making an adjustable panhard bar and am only running individual schrader valves for now. All for the cost of bags and fittings and a little labor.
Then I can also lower it to the bottom for loading bikes, lawn mower, wheel barrows, etc.
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
02-17-2014, 09:56 AM | #10 |
The frame I bought from Hart Rob came with a 4/6 drop. I want to use my truck as a truck and don't want to butcher the frame,so will be swapping bags in place of coils on rear. I also like having the option of running the more traditional hot rod rake when the mood strikes,which is actually just equally lowered front and rear/stock stance but lower.
Greg,that's the rule of thumb...The rear sits 2" higher in stock form. I believe that's what the original literature shows as well. So,you are talking about a 1 1/2" difference which will give a 1/2" rake(?). Would that be detectable? I doubt it. Whenever you lower the rear on coil spring trucks it offsets the rear to the right. By 3-4" it is noticeable. You would want an adjustable panhard bar to center the rear. The other rule of thumb is up to 4" drop+ adjustable panhard/4"+ = Super Trac bar,which actually relocates mounting points to keep the bar at an effective angle.
07-09-2016, 07:27 PM | #11 |
4" spring drop in back is the max be for you need a adjustable track bar
02-16-2014, 12:57 PM | #12 |
I did a 2/3 drop. I like a small rake.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
02-16-2014, 01:28 PM | #13 |
02-16-2014, 01:48 PM | #14 |
Moderator
This is the lowest you can go with a static drop, 5/7. It needed notching at even 5" in the rear.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
07-07-2016, 09:21 PM | #15 | |
Any rubbing issues front or rear?
-RafaeL |
02-16-2014, 02:50 PM | #16 |
CAN'T FIX NOTHIN
My 3/5
02-16-2014, 04:17 PM | #17 |
With a 3/5 spring and a adjustable panard bar, you will bottom out. I would use a combination of springs and drop spindles to keep as much travel as you can. The rear of my truck needs a C-notch. They make notches that you won't have to modify your bed. When I do get the notch I am going to two more inches in the front and rear. jmho.
Have fun. |
02-16-2014, 06:46 PM | #18 |
Thanks everyone for your input, 2/4 sounds like what I want to do.
Does anyone out there have a pic of a step side with that combination? specks70 |
02-16-2014, 08:16 PM | #19 |
This is as close as I have for an example for you. This is 3-5 all springs. Custom made track bar to center rear end. No notch. Don't haul anything except my but, and I personally have not bottomed out any. Tires are 245/45/20 and are about 28.6 inches tall. I have plenty of ground clearance and I can drive this thing as I like with no worries. This is a little lower than you are asking for but maybe a good reference.
02-16-2014, 08:18 PM | #20 |
Here is another.
02-17-2014, 04:55 AM | #21 |
02-17-2014, 07:50 AM | #22 |
02-16-2014, 07:38 PM | #23 |
the boat guy
4-6 no notch spring only drop. Is it right, no. Does it work, yes.
I couldn't imagine anybody running this setup and still using it as a truck. Lol Probably the same kinda guy who would haul wood with a swb and tow with gasp* peep mirrors.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
02-16-2014, 08:01 PM | #24 |
looks nice. Love it.
http://67-72chevytrucks.com/vboard/s...0&referrerid=0 |
02-16-2014, 09:10 PM | #25 |
Wow 19GM71, I do like that. Very impressive. Good looking truck.
A question though. . . How would I know what length "track bar" I would be needing?? Last edited by specks70; 02-16-2014 at 09:33 PM. Reason: Incorrect question |
