Old 02-16-2014, 05:19 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Is this metal shield common to K5's?
I've been meaning to ask about what looks to be a metal heat shield on my K5 that's affixed to the floor pan and is between the exhaust pipe and a Hickey gas tank on the driver side just posterior from the rear axle. I don't recall anything similar on my 71 Blazer but I owned that a long time ago. Anyone else have this "shield". It's not a remnant piece of the gas tank skid plate as far as I can tell.
Old 02-19-2014, 07:25 PM   #2
Chulisohombre
Chulisohombre's Avatar
Re: Is this metal shield common to K5's?
If its in the rear at the end of the quarter panel I believe mine has it. Looks like it keeps the fuel tank breather lines from getting hit by thrown debris from the tires.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 02-19-2014, 11:33 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Yep in the rear. Must be a rock guard then. Thanks that's helpful info. Pete
Old 02-20-2014, 10:44 AM   #4
Chulisohombre
No problem man. Your posts give a lot of help to people so at least One of us can help ya out.
Old 02-20-2014, 12:18 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks!
Old 02-20-2014, 08:48 PM   #6
Dirt's72
Finally got to look at mine. So it appears from your pics to be mounted on the inside of the frame. Mine has two brackets in that area with bolts coming through from the inside spare tire mount. No sign of any heat shield on mine. Is the shield on yours welded to the floor pan?
Dirt's72 is offline   Reply With Quote
Old 02-20-2014, 08:53 PM   #7
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks for looking. I'm not sure but believe this is bolted in place rather than welded. Am curious if it's a GM piece or came with the aftermarket Hickey tank. This is just behind the rear axle and should be forward of the spare tire mount
Old 02-20-2014, 10:40 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
GM offered a one year only auxiliary gas tank option mounted in the rear K5 style for pickups in 1970. Can't recall those that I've seen (pics of anyway) having a similar guard.
Whatever it is I've got to yank it and paint it
