02-18-2014, 11:54 AM | #1 |
staying with 6 lug for now
1969 w/ 4 drums. I need to swap from drums to disc. I know there are a LOT of threads on this but just to clarify and make sure I've got it say I want to source a complete brake setup from a 73-87.
I'll need rotors from an 88-98 2500? Do I need different ball joints? what else? Last edited by oldcane; 02-18-2014 at 12:04 PM. |
02-18-2014, 12:00 PM | #2 |
67-72 parts collector,…
Re: staying with 6 lug for now
What year truck?
What suspension is under the truck now?
02-18-2014, 12:03 PM | #3 |
Sorry about that. I did an edit.
02-18-2014, 12:09 PM | #4 |
The most simple swap would be:
1) 63-70 conversion spindles ($229 EVERYWHERE) 2) 6-lug aftermarket rotors 3) 71-80 HD calipers and bearings 4) 71-72 M/C 5) 71-72 or aftermarket prop valve
02-18-2014, 12:12 PM | #5 |
I can find plenty of kits. I specified I wanted to source these from a donor or two.
02-18-2014, 12:19 PM | #6 | |
It's spindles and rotors. They rest can be sourced locally at your parts store. IF you want to use a donor. Use 71-72 truck parts or 73-87 truck parts. Swap the entire crossmember assembly and then add these rotors. http://www.summitracing.com/parts/clp-cp4r-6 MY OPINION,... all donor parts are wore out junk. All tie rods, ball joints and bearings need to be replaced. I was trying to help you by NOT mixing and matching parts. Conversion spindles are the best answer for 60-70 drum brake truck owners wanting disc brakes. No ball joints to change. No tie rods to change. Sorry I wasn't helpful enough. Can someone else help?
02-18-2014, 12:21 PM | #7 |
No, no, You were very helpful. Now I know I need to spend less time on this forum if any at all. I know now that any question I ask is just wrong. I already knew that. I'm married.
02-18-2014, 12:43 PM | #8 | |
Happy to be here
Keith layed out everything you needed to do your conversion.
02-18-2014, 12:23 PM | #9 |
You didn't ask the wrong question.
I just answered you wrong.
02-18-2014, 03:07 PM | #10 |
Its all good on here these guys know their stuff.
now looking at your title I don't think you can do a swap with donor truck stuff and keep your 6 lug. I think all these common "salvage yard swaps" are gonna get you 5 lug. Now a kit from a vendor will keep you 6 lug but at a price. Good luck Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
