Old 02-20-2014, 05:39 PM   #1
K10mashup350
S10 air shocks.... Will they work?
I have been offered a set of air shocks out of an s10 for my 73-80 frame, my question is will they work ie. bolt in place, the truck is static dropped 4/8 with 5 leafs in pack an I need new shocks as mine are blown an I would love the fact of being able to put more air in the rear when needed for heavy loads/hauling.
The s10 is a 95 that they came out of
Thanks in advance guys!
K10mashup350 is offline   Reply With Quote
Old 02-20-2014, 10:52 PM   #2
LONGHAIR
Re: S10 air shocks.... Will they work?
You would have to measure them. It is way to hard to guess at something like that with lowering involved.
That said, I am not a fan of air-shocks in the first place. The shock mounts were never designed to support the weight of the truck, much less added weight of cargo.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-20-2014, 11:18 PM   #3
K10mashup350
I had him measure the "stroke" of the shock and at it's max it's aprox. 21"-22" and fully compressed is 17"
To me it sounds like it should work, is there any other measurements I shouldn't concerned with?
Old 02-20-2014, 11:43 PM   #4
mongoose
mongoose's Avatar
that seems way too long.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 02-21-2014, 09:03 AM   #5
K10mashup350
How long of shocks should I be looking for, I did try the search but didn't find it, I'll keep looking for the specs of drop shocks an try to base it off that
Old 02-21-2014, 09:03 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
S10s use different upper mounts. They use a crossbar type of setup on the top whereas the 73-87 trucks use a normal eyelet.
And your lengths sound quite long. My lowered 78 rear shocks are a good bit shorter than those numbers.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
