Old 02-21-2014, 06:12 PM   #1
cranky84
Divorced choke question
I've been trying to fix the idle on my truck for awhile now and can't seem to get it. It's a 327 with a 2 barrel qjet. I replaced the coil spring. Thought that was the problem but it wasn't. When I start the truck It seems fine but when the truck warms up and I push on the throttle it idles really high and the butterfly is stuck ., I can move it back manually under the good. Any one have a my suggestions on what Is wrong?
cranky84 is offline   Reply With Quote
Old 02-21-2014, 06:46 PM   #2
stomper
Junior Member
stomper's Avatar
Re: Divorced choke question
Has the carb been apart lately? The choke linkage and such is a real puzzle that has to be assembled correctly.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 02-21-2014, 07:19 PM   #3
cranky84
I have not taken it off. I just bought it tho so I don't know. I ordered a choke pull off , will that maybe work? A guy at my work said it is the exhaust crossover under the intake. But it seems like the coil spring is getting hot so I can't see it being that...
Old 02-21-2014, 07:29 PM   #4
geezer#99
geezer#99's Avatar
THey don't make 2bbl qjet. They do make a dualjet that looks like a qjet. Or do you mean a rochestor 2gc.
Choke pull off won't help. Yours is working already or it wouldn't run.
Maybe take a pic of your carb.
geezer#99 is online now   Reply With Quote
Old 02-21-2014, 07:54 PM   #5
68gmsee
Active Member
68gmsee's Avatar
If the linkages are not binding somewhere, try moving the throttle by hand slowly while looking into the throttle body to see if the butterflies are sticking. It may be gummed up or could be a throttle body butterfly shaft that has a flat spot. Try cleaning first and see what happens.
I had one that no amount of cleaning and spraying kept it from sticking. I even put a stronger spring on it but wound up putting another carb on the engine. If that is your problem, you can have a carburetor shop, repair shop or even a machine shop install shims in it. I'm in the process of trying to find a shop that will do my monojet. May have to bite the bullet and get a shim kit.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 02-21-2014, 08:01 PM   #6
cranky84
Sorry I think it is a Rochester. I don't know what it is called but on the other side of the carb where the choke connects to looks like a ratcheting system with a screw on it, and if it's supposed to ratchet it's not. I can move it back myself but won't when I'm driving it. It idles high when at a stop light. Name:  image.jpg
Old 02-21-2014, 08:15 PM   #7
geezer#99
geezer#99's Avatar
It's a rochestor 2gc.
You can bend that long rod a bit to make it kick off the high idle.
The high idle screw is the same as the low idle screw. Located on the other side of the carb. Rides on the cam. You call it the ratchet thing.
Take a pic of the other side.
THere's another link on the other side that's attached to the choke.
Old 02-21-2014, 10:15 PM   #8
cranky84
Size:  59.1 KB. I looked at the old coil and the spring was on the other way than the old one. So I switched it and seems like it fixed it. Before it was when it was heating up the choke would go up so it would idle high. So I switch the coil so when it heats up the spring goes down so the idle goes down too. Kinda weird that that's how it came in the box, wrong
