Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-22-2014, 02:39 AM   #1
Super73
Super73's Avatar
You know your motor is apart too often when...
I am sure there are a lot of us that can add to this. I will start.
You know your motor is apart too often when:
It takes you 1 hour and 30 minutes to get it out by yourself
You can collect the mix of tools you needs before you even start. (In my case both metric and standard)
It takes you less than 1 hour to assemble from Shortblock to complete turn key ready minus dropping it in and wiring it. But that's only another hour.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 02-22-2014, 04:06 AM   #2
BigDan3131
BigDan3131's Avatar
Re: You know your motor is apart too often when...
You can pull the tranny from the truck laying on your back in less than 30 mins and then pull the motor with your eyes closed...almost.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 02-22-2014, 09:58 AM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
When you have to replace the bearings in the wheels of the engine hoist!!!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 02-22-2014, 01:03 PM   #4
cableguy0
You know exactly what does and doesn't have to come off in order to get the engine on the stand the fastest. You just remove the components to the get the belts off instead of bothering with the belt adjustments.
With air tools I got to the point I could yank the engine in 35 minutes from my 84. Everything was about as simple as it could get for hookup. One -8 fuel line. Pull the carb and attach the lift plate. Then drop the alternator and ps pump. Headers were the biggest pain. Never did find a quick way to get them out especially the bolts that had to be wrenched out.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-22-2014, 11:52 PM   #5
softballnrd27
Always a work in progress
softballnrd27's Avatar
When you have more pics of it out of the truck than in it!!
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 02-23-2014, 12:01 AM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
When you beat the firewall back to remove the bell housing bolts easier.
Old 07-14-2014, 04:52 PM   #7
TheBlueBomber
TheBlueBomber's Avatar
Hahaha that made me laugh
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 08-16-2014, 11:17 PM   #8
moggey01
ummmm , using a hole saw and cutting holes so they can be removed with an impact from inside the car
moggey01 is offline   Reply With Quote
Old 04-18-2014, 05:27 PM   #9
Blue Rat
When its a weekend thing.
Blue Rat is offline   Reply With Quote
Old 04-21-2014, 11:14 AM   #10
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
When you have to ask this question..
GMR-PERFORMANCE is offline   Reply With Quote
Old 04-21-2014, 02:40 PM   #11
Wasted Income
Boosted Member
Wasted Income's Avatar
You put quick disconnects on your tranny cooler lines
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 05-31-2014, 05:12 PM   #12
68Gold/white
your wife isn't getting mad at you over how long this particular job is taking....
68Gold/white is offline   Reply With Quote
Old 05-31-2014, 09:17 PM   #13
slowtruck
When you put all your bolts in the same bucket because you know where they go!
slowtruck is offline   Reply With Quote
Old 06-05-2014, 08:30 AM   #14
RocketChevy56
Certified BFH Operator
RocketChevy56's Avatar
When you make brackets with D-rings on them, and bolt them to your heads so you don't have to pull your intake or carb and can just hook a chain to them!
- 1969 swb C/10 fleetside -LSx swap and Resto in progress
LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay...
-1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle
RocketChevy56 is offline   Reply With Quote
Old 06-05-2014, 12:54 PM   #15
PGSigns
PGSigns's Avatar
When you have to heliciol all the holes due to wear.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-05-2014, 10:29 PM   #16
Marv D
Marv D's Avatar
when you say TO HELL WITH IT,, I'm done!
The truck is going back to just a street truck,, and getting the Nova all re-certed. At least that POS stays together a bit longer.
Old 06-06-2014, 04:56 AM   #17
Blue Rat
Everything ok Marv?
Old 06-06-2014, 09:38 AM   #18
Marv D
Marv D's Avatar
Yeah,, thanks for the concern guys . I'm just tired.
Haven't touched the truck since it broke the pushrod in March. I'm sure it's got a hurt lifter. Has to come apart to find out.
Think I've just kinda lost interest in even fixing it. "EVENTUALLY" Going to put the heads on a nice little pump gas 383 I built for it originally, with a hydraulic roller, and headache free single carb,,,, and see what happens. I'm thinking its apt to find a new home.
Old 06-06-2014, 12:31 PM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You know your motor is apart too often when you look at a Fiat and think..."man, it would be nice to own a reliable car..."
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-06-2014, 09:42 PM   #20
Super73
Super73's Avatar
When it is still apart... Yes, mine is still apart..
Old 06-07-2014, 12:32 AM   #21
dwcsr
Hollister Road Co.
dwcsr's Avatar
When you try to think of a way to put zippers and snap buttons on everything
Old 08-17-2014, 12:44 AM   #22
69chevytrucker
69chevytrucker's Avatar
i have been pulling old chevy engines for over 20 yrs that even if the engine is supposed to come out the bottom i still pull it out the top and can do it twice as fast as most people
69chevytrucker is offline   Reply With Quote
