Old 02-23-2014, 08:47 PM   #1
ChevyJr
Junior Member
ChevyJr's Avatar
Rear Frame Cross member
Does anyone know where I could locate this piece of the frame online or on the forum?
I've measured from both sides of the frame and it appears to have been straightened at some point. I need to find the correct frame measurements for a C10 Shortbed to ensure that in fact happened, but I am installing a rear mount gas tank and what to replace this before doing so. Any help is greatly appreciated. Thanks.
ChevyJr is offline   Reply With Quote
Old 02-24-2014, 03:43 PM   #2
Lugnutz65
Lugnutz65's Avatar
Re: Rear Frame Cross member
I think you will need to get that piece from a donor truck. My 1965 frame was very straight but the rear frame crossmember was bent by the previous owner hooking a chain to it and trying to pull a stump - at least that is my theory.
I had to get a straight piece to replace it from the salvage yard. Grind off the rivets. I drilled the rivets out and luckily it worked. The salvage piece fits like it should so I know the frame rails are not damaged.
Please notice that the big crossmember (not the little skinny one) that is 2nd from the very back is installed at a slight angle. That is the way it is designed. I think it allows clearance for the panhard bar (track bar). I just don't want you to think it's crooked. The 4th photo shows the frame of a 66 parts truck I sold. You can see that the large crossmember that is 2nd from the rear has a slight angle. It is supposed to be at a slight angle, but the rear most crossmember goes straight across.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 03-08-2014, 01:35 PM   #3
Mikes66ChevyC10
Mikes66ChevyC10's Avatar
Thank you for posting your pictures especially the 4th one!! We got the bed of my 66 C10 off yesterday and I noticed how the cross member (the big one and the little one for the spare tire) were not straight so I thought for sure my frame was bent. My frame looks exactly like the one in the 4th picture were you can see the slight angle. So happy to find out it's normal!
1966 C10 Stepside swb
http://67-72chevytrucks.com/vboard/s...d.php?t=617778
Mikes66ChevyC10 is offline   Reply With Quote
Old 02-24-2014, 04:48 PM   #4
chevyrestoguy
chevyrestoguy's Avatar
If you can wait about a week, I'll have one removed from my '64. I don't plan to reuse it, because I'm doing a custom spare tire mount and adding a hitch assembly. If you need measurements in the meantime, let me know.
Alex
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 06-10-2014, 02:30 PM   #5
jdp
jdp's Avatar
So this is normal? I just installed a new tank under the bed of my 65 and I noticed that the rear cross member right in front of where I put the tank is slightly askew. When standing at the tailgate and looking down onto the tank (beds ripped out), it looks like the left side of the cross member was attached a couple inches forward of the right side. I've had my truck up on the lift and the frame looks clean, no signs of being bent.
jdp is offline   Reply With Quote
Old 06-10-2014, 04:04 PM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Yes this is by design. One for clearance of the panhard bar but MOST importantly, this is to help keep the frame from "racking". If all of them were equal length, it could allow the frame to create a parallelogram. By placing this one crossmember at an angle, making it longer then the rest, you would have to expand or compress the frame at that point to get it to rack into a parallelogram. Those GM guys were pretty smart.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-10-2014, 08:52 PM   #7
McCoyAZ
McCoyAZ's Avatar
So Chevy Mike....
I need to move that cross member that is askew up about 6 inches to get the clearance I need for my short stepper tank.....as long as I move it forward equal distance I would be okay with doing that? And I am going to weld a flat bar across the rear as well.
Don't mean to hi jack this thread but it is exactly what I was just going to ask.
McCoyAZ is offline   Reply With Quote
Old 06-10-2014, 10:08 PM   #8
chevy_mike
chevy_mike's Avatar
I don't know if you have enough straight frame to move it but in theory, if you move it equally forward, you would be fine. If you have a coil rear setup, I don't know if the panhard bar is going to clear. If leaf springs, likely won't be a problem but check clearances.
