![]() Join Date: Feb 2010
60-63 frt bumpr fit 64-66?
Will a 60-63 front bumper fit a 64-66. Im interested in it for my 66.
Re: 60-63 frt bumpr fit 64-66?
I think so but I would wait for some other replies.
The 63 bumper will. The 60-62 has a different frame, so different mounting location.
Also....the 60-66 used the same rear bumper on stepsides...just different mounts
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Ok thanks guys
But Found Her 25yrs Later!
I confirm the post of 1963c-10.
60-62 are different than 63-66.
The confusion about the 63 is the transition from X-Frame to Ladder Frame, and the wrap around front window.
60-62 used X-Frame. 63-66 used Ladder Frame. 60-63 used the wrap around window. 64-66 did not. So 63 is an odd transitional year.
Senior Enthusiast
In reality a 60-62 bumper should also fit just fine on a 63-66. The only difference I'm aware of is the vertical distance between the inboard bumper bolt holes being closer together on the earlier bumpers. If you didn't mind drilling new holes, the rest of the bumpers should be the same. If you installed bumper guards over the inboard mounting holes, the extra holes would be hidden behind the guards.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#8 | |
