thump426er SPID Line Items Question 02-26-2014, 09:19 PM
Elliot949 Re: SPID Line Items Question 02-26-2014, 11:10 PM
special-K Re: SPID Line Items Question 02-26-2014, 11:43 PM
thump426er Re: SPID Line Items Question 02-27-2014, 01:00 AM
SS Tim Re: SPID Line Items Question 02-27-2014, 04:52 AM
Keith Seymore Re: SPID Line Items Question 02-27-2014, 08:26 AM
thump426er Re: SPID Line Items Question 02-27-2014, 05:49 PM
RenoKeene Re: SPID Line Items Question 02-28-2014, 11:02 AM
SS Tim Re: SPID Line Items Question 02-28-2014, 01:17 PM
best view Re: SPID Line Items Question 03-01-2014, 07:41 AM
SS Tim Re: SPID Line Items Question 02-27-2014, 06:44 PM
Joesjunk Re: SPID Line Items Question 02-27-2014, 10:44 PM
Spartan Re: SPID Line Items Question 03-01-2014, 07:48 AM
SS Tim Re: SPID Line Items Question 03-01-2014, 01:31 PM
thump426er Re: SPID Line Items Question 03-03-2014, 10:07 AM
02-26-2014, 09:19 PM | #1 |
Hi there, have a couple questions for you all from 2 trucks SPID's and what they are.
1968 swb 2wd auto column shift (now 700r but not sure what was in it originally): - option #04Z62EA Custom C&C Equip - option #04MIOAK Overdrive Trans (I didnt realize there was an overdrive auto trans back then??) 1972 K20 two tone paint: - option #400188 Special Paint (the SPID doesnt say color in any of the line items, just this "special paint" item, does this just reference that it is a two tone paint job?) Thanks and appreciate any input you may have. |
02-26-2014, 11:10 PM | #2 |
This sight should help you with all your specific trucks codes...
http://www.gmheritagecenter.com/docs...olet-Truck.pdf |
02-26-2014, 11:43 PM | #3 |
The overdrive transmission was a 3spd manual +1 overdrive gear. It engaged using a cable with a pull that mounted under the dash.
Option Z62 was "Custom" comfort & convenience
02-27-2014, 01:00 AM | #4 |
Thanks to both of you, that helps, and,,, looks like I have some reading ahead of me. Very useful info in there for sure..
02-27-2014, 04:52 AM | #5 | |
The M10 was a three-speed manual trans (column shift) with an overdrive element added to it. It was electrical in operation using solenoids, relays and ignition interruption to upshift at part throttle. The cable control was actually a defeat funtion to lock out the unit when loaded. "Special Paint" means exactly that, other than standard production. It could be used for non-production colors like EZ Haul rental green or more often production colors in a non-standard arrangement like this truck in a reverse special two-tone of ochre and white. There is no way to determine the color or arrangement just from the RPO code that I am aware of.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
02-27-2014, 08:26 AM | #6 | |
The preceding and subtended characters are "dummy" characters, placeholders, if you will. At one time they represented a "functional name address", sort of a sub-RPO, but by the time I came along they didn't really mean anything, and can be disregarded when researching your option content. This was implied above but had not yet been stated explicitly. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-27-2014, 05:49 PM | #7 |
Thats very interesting. So here is a picture of my 72, guessing this is ochre with the white. However this seems "normal" to me. My When I bought this maybe 4 years ago I bought it from the original owners son. He said it had never been painted or in any accidents, only had Warn hubs thrown on and a spray in liner. Garage kept its entire life apparently and looked that way when I first saw it. There doesn't appear to be any evidence of painting etc. Is there something i should look for that might be indicative of a "special" paint? Or is this pattern (which seems quite common for 72) considered special. Here is the SPID for my 72, is there another item that I'm not thinking might reference the paint etc, seems obvious to me but just in case.
Thanks again, great info from you guys. Never knew there was an overdrive which you actuate under the dash. |
02-28-2014, 11:02 AM | #8 | |
Florida Edition
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
02-28-2014, 01:17 PM | #9 | |
But during the 67-72 period the suffix letters/numbers were still in use, more so in the earlier than later years. They were used to denote a variation of the RPO code. As an example in '68 the V37 Chrome Bumper _ _ _ was common to all applications and it was the suffix letters (and description) that denoted if it was an optional front AA, an optional rear or optional front and rear EA (shortbed fleetside).
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 02-28-2014 at 01:33 PM. |
03-01-2014, 07:41 AM | #10 |
its much darker I have the exat truck with the exat options but mine is orche with original paint and air mine also does not show wheel option its your brother
02-27-2014, 06:44 PM | #11 |
From that picture its hard to tell what the color might be. To me it looks browner than ochre.
The ochre and white I posted up is a code 4001WC vs your 4001BB. There is undoubtedly something in the exception codes (suffix letters) that I may eventually determine by say 2072. If your truck is a "Z" Fremont truck then look about behind the seat for the build sheet as I'd really like to see that clearly. Getting to the bottom of what you have may be difficult if even possible. It could have been as simple as body color wheels. P/M an email if you want to explore this. On the overdrive it was a pull to deactivate otherwise it automatically shifted in and out of O/D relative to throttle position.
02-27-2014, 10:44 PM | #12 |
It does appear to be darker that Ochre.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
03-01-2014, 07:48 AM | #13 |
Looks like white below the trim, color only above the belt line and a white roof.
'69 K20 350/4 speed/Rockwell/D44/HO52. "orange rhymes with door hinge" |
03-01-2014, 01:31 PM | #14 |
While that is possible, I blew the picture up the first time around and convinced myself then it is the bodycolor down there. However it is lightened a great deal by the snow reflection.
03-03-2014, 10:07 AM | #15 |
Sorry, didn't pay attention the color below wasn't that visible. Here is a better side to show the color below.
The rear bumper was the usual checker plated top work bumper. I'll dig around for the build sheet and post up once/if found. I'd like to know that color. I know this isnt the be all end all but this website for paint matching http://www.paintscratch.com/touch_up...let-Truck.html none of the colors really match the truck when I compare say inside the glovebox or interior where its never/less been sun affected. |
