Check The Champ, Demonstrator
![]() Join Date: Jun 2009
No-SPIN Differential INFORMATION
I got his envelope today, that was to be included in the glove compartment ( dispatch box ) when the NoSPIN differential was optioned..
Front of envelope. 4 7/8" x 7 3/8" Back 2nd envelope inside of first. Blank on the back. 4 1/2" x 6 3/4" This single page is folded in three. 6 1/2" x 10" Fold out. Front page. Folded out completly 6 1/2" x 15 5/8" Booklet. 4 1/8" x 6 5/8"
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Re: No-SPIN Differential INFORMATION
Aerotruk63....that looks a lot different than the 17 spline Eatons like I have. The brochure you have is for the Detroit locker...correct?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 02-28-2014 at 12:43 PM. |
![]() Join Date: Aug 2010
Thanks for posting, Norm. Up until now, I've found the peculiarities of the no spin axle have been somewhat of a mystery and vary depending upon who is telling the story. This is great info, right from the source!
and it aerotruk63 not Aerotruck63, you just don't care! lmao!
Aarg.....I do that all the time. Sorry. I'll get it right one of these days
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
I would say yes. For the heavier than 1/2 ton trucks. I have the same Posi unit in my 63 and have another to put in the K10 eventually. The NoSPIN brochure says you can have it in the front differential of a 4WD as well. Wonder if these Eaton Posi's can go up front in a 1/2 ton?
1963 Silver Book ![]()
Thanks for sharing the literature. The Detroit locker is also the one pictured on the Posi cab tag.
Interesting KS10 on the envelope and the Cab Tag. Do you know what size/model/brand truck that tag's from 1963c-10?
By the way copy and paste my avatar in the future. lol ![]()
That tag came from a 62 c-20. I know its not the correct tag for the posi I'm using, but I wanted a back cab tag to put in the 63 when I install the posi. It was held in by 4 screws.
Heres the truck it came out of and the mounting location. From the pictures it looks to be directly above the driver side gas tank strap.
#10 | |
DEE-troit locker baby, hey oem4me Yelmer(mike) was looking for that same back of the seat sticker....
![]() Join Date: Aug 2008
good info
Wow, another ex Bell Telephone truck ( special order green paint). These C 20 No Spins have a problem of "racheting up" on left turns. Eventually they wipe out pinion bearings and your rear end howls going down the road. No problem, at 250K when this happened to me, I junked the 4.57 No Spin it and replaced it with a 4.10 standard differential, quiet again.
Thank you for the responce.
I hope you saved the grill guard as well?
#15 | |
This truck above was parted out here on the forum, and I believe another member did save the grill guard though.
#16 |
There are some copies that were made by a forum member if anybody is interested. Link: http://67-72chevytrucks.com/vboard/s...d.php?t=635486
#17 |
...just another truck junkie..
![]() Join Date: May 2009
The switch to a sticker may have happened sometime in '63. My '63 C20 has the NoSpin rear and has a sticker in the cab, left side, behind the seat. I also have all the literature that came with it. It was in the glove box when I got the truck and is pristine.
Mike "Bear" Shea |
#18 | |
So far I can verify an aluminum tag on a 62, but unsure of plant location. And your 63 seems to be the 1st documented sticker cab that posted. I know its probably petty, but its the small details that really pull the period correct restorations together.
#19 |
The small details are what help us solve the mysteries! My '63 C20 was assembled at the Janesville plant.
Mike "Bear" Shea |
#20 |
Ok, thanks. And I agree about the mystery solving. If the trucks had been documented as well as the cars we'd have a lot more info. But thanks to sites like this one I think we've accumulated quite a bit more than what was available 10 years ago.
#21 | |||
#22 | |
#23 |
the reproduction sticker was from a 67-72 truck if that helps identify that label any.
#24 |
A little further information on my truck. I pulled the papers out last night to get the info. The vin is 3C254J126938 and it was delivered to the buyer on April 19, 1963.
Mike "Bear" Shea |
