72 C-10 build up.
Well I got the new project pick up today.
13 hours on the road to go pick it up and bring it home. Known issues: power master cylinder leaks,won't hold a charge, & both wing windows need to be fixed. Here is a picture the previous owner sent to me: ![]() I also have a 71 C-10 that is an almost twin to it in color, but it's in far worse condition than the above pictured 72. But it does have alot of parts that I will be pulling off of it to put on the new 72. Wheels... has 15" x 8" ralleys on it now. I like them, but they need to be media blasted/powder coated and new tires. By the I do that for a few more benjamins I could have some 17"/18" aluminum wheels on it... ![]() I will eventually put an LS into it, not sure how soon though. Oh ya, only options: PB, PS, & Factory cab lights. Will post up some better pictures soon, we are expecting 2"-6" of snow tonight. L8R |
Re: 72 C-10 build up.
looks like it may have been sitting awhile in the same place and it was outdoors. Have fun!!
Managed to get the cab all cleaned up and took some pictures:
Factory U01 cab lights: Build sheet: ETA: the outside is filthy due to the snow/slush road trip across the state during the snow storm last weekend. Waiting for the weather to warm up before I get carried away working on this C-10 L8R |
Sent out the wheels to get media blasted and powder coated.
Had new tires put on & I already ordered the new center caps. I do not have any history on the suspension work done on this truck. It is definitely lower than factory… but I do not know by what means. There are no lowering blocks in the rear, but I think a flip kit was done. The front I have no idea if it has drop spindles or lowering springs. I want to go 2" lower than it is right now, all the way around. Oh ya, I already swapped out that nasty dented up tailgate since the pics were taken. Thanks. |
![]() Join Date: Sep 2012
Really clean truck looks like its mostly surface rust,pretty solid.The wheels came out nice.What is the tire size 275/60/15.
1971 c10 custom deluxe fleetside swb LS3 w/BTR stage IV cam,4L85E w/3600 stall 67-72chevytrucks.com/vboard/showthread.php?t=558024 |
Yes, 275-60-15 on 8" rally's.
Quick update since I got her home:
- rebuilt rear end, new 3.50 gears, new heavy duty axles, new posi - rebuilt rear drum brakes - rebuilt front disc brakes - new 8" mini brake booster installed - new adjustable pan hard bar - new front & rear brake lines - new front & rear shocks - 2" lowering blocks for the rear - cut 1 coil out of front springs - new U-joints & carrier bearing - driveline shortened 3/4" & balanced - new 275-60-15 tires on all 4 - powder coated 8" wide rally's on all 4 - new alternator Front end alignment done after the below picture was taken. She's a runner/driver now. ![]() |
Looks good!
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
Here is the engine that will eventually go into her:
LQ4 6.0 LS Will eventually be a single turbo blow through carb version. |
