Old 03-02-2014, 01:07 PM   #1
jbristo67
resident oilfield trash
jbristo67's Avatar
AC vent problems.
Some of my AC vents flop around and mostly point at the floor. Will simply buying new ones fix this or is there somthing else I need to fix too?
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-02-2014, 01:30 PM   #2
nekkidhillbilly
Re: AC vent problems.
you can put a oring on the shafts that stick out of the vent. this takes up slack and keeps them pointed right.
nekkidhillbilly is offline   Reply With Quote
Old 03-02-2014, 01:32 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
You can put some shims in them to tighten them up. It's very easy to do. Heck I've made them from cardboard and plastic. Plastic ones seem to last longer and hold up. I used old plastic washers and just cut them in to a wedge shape where I could get them on the left and right. Helps stiffen the vents up and if done right you never see them on the outside.
I did this while the dash pad was out so I had access to the backside. I should have led off with that.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 03-02-2014, 01:33 PM   #4
nekkidhillbilly
http://forum.73-87chevytrucks.com/sm...p?topic=9467.0
rubber hose works sometimes o rings do. just need some kind of soft bushion to keep em tight basically.
Old 03-02-2014, 09:25 PM   #5
rs74
rs74's Avatar
I have also heard sticking on the softer side of a piece of velcro. Never tried it but have heard about it.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
