Old 03-04-2014, 08:19 AM   #1
Dirt's72
3.07 posi rear end with:
How would this rear end match up with a th350 and 350 motor in a 72 4x4 blazer?
Other option is with a 69 292 power glide set up?
It would be nice to have that extra tire spinning on some of the hunting trips I go on. Thanks.
Dirt's72 is offline   Reply With Quote
Old 03-04-2014, 11:41 AM   #2
Bigdav160
Bigdav160's Avatar
Re: 3.07 posi rear end with:
What gear do you have in the front axle? And what diameter tires?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-04-2014, 01:20 PM   #3
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
It's my experience, many of the 350/350 setups I have come across in Blazers had 3.07/3.08 standard.
I have seen a few 3.73 combo's too, but as mentioned you need to match the front & rear.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 03-04-2014, 03:29 PM   #4
Dirt's72
My blazer currently has 3.73 front and back. Tires will be stock 235 75 15.
Like I say other option if not doable for blazer is on my 69 with a 292 with power glide and stock tires.
Old 03-04-2014, 01:44 PM   #5
Mike C
Mike C's Avatar
Base model diff ratio in a 350 powered 4x4 '71-'72 would have been 3.07 gears while the optional gear was 3.73. I own (2) '72 Jimmys about 1200 serial #'s apart. Mine I learned to drive in is a 4 speed and came with 3.07. The other one that will eventually be my 10 year olds "project" is 3.73 and an auto.
What size tire do you have is a great question. IMO, 3.07 just isn't enough gear for 33" tires. 3.73 is ideal for that and 4.10 for 35's.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-04-2014, 02:31 PM   #6
Twisted78SS
Wide n'Low
Agree on the size of the tires,
I have a 75 Blazer with a 4 spd/205 so, (same 1:1 final ratio) and 3.07 gears, running 33's. Sucks around town and on even seemingly minor hills, but great running down the freeway..
Air Force Retired
Old 03-04-2014, 07:25 PM   #7
67swb72klb
67swb72klb's Avatar
3.07 is not too bad as long as your tires are no bigger than 31" with stock trans
just put the t/c in low range when you have to get with it
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is online now   Reply With Quote
