![]() Join Date: Sep 2013
Upper Radiator Hose # 454 w/serpentine belt?
I have a crate GM 454 Gen VI with the serpentine belt system in my 67' and I am hoping someone has "been there done that" and can give me a part number for a molded upper radiator hose that gives adequate clearance around the alternator and serpentine belt. What I have in there now works but has just slightly more than a gnat's azz of clearance. I think it is just a matter of time until something rubs.
Anyone? ![]()
1967 Shortbed Stepside - GM Crate 454HO 425HP/500 lb-ft, long tube Hedman ceramic coated headers, serpentine belt drive, Built 700R4, 12 bolt 3.42 with Eaton posi, 4 wheel disc brakes, OldAir A/C. 69' Corvette Lemans Blue. Painless Wiring Harness. Everything from the ground up is either new or rebuilt! |
Re: Upper Radiator Hose # 454 w/serpentine belt?
I had a similar issue. I couldn't find a good fitting hose because the angles were wrong. I got a aluminum thermostat housing that swiveled. It gave me a few more options on hoses. Here is an example http://www.jegs.com/i/Billet-Special...90220/10002/-1
#3 | |
I used a 45 degree swivel thermostat housing and the stock hose. Just takes a slight twist to get the hose to clear the belt.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
"Stock hose" for what application?
Good idea but I am trying to keep the underhood look somewhat "stock-ish" if you will and wanted to stay with a molded rubber hose.
That is why I came to the forum with the question...I have found lots of "chicken lips" in the search!
![]() Join Date: Mar 2003
Not sure, but what about a t-stat housing off of an LS engine say an '02 with the hose that wraps around behind. (originally the ac on an LS)
