03-08-2014, 02:14 AM | #1 |
i have HAD IT with this truck!! still randomly dies...
Alright I made a thread a week or so ago about my truck randomly dying on me, so i lowered the floats on my new 780CFM quick fuel carb to the proper level, new plugs, new wires, new ignition switch, took out a kill switch under the dash and just eliminated it thinking the switch was bad. IT RAN GREAT for 3-4 hours tonight, perfectly FINE! then all of a sudden it started dying on me at random times a couple miles from home, it would start right back up, every time, and run for a few minutes and die while driving, I'd pull over and fire it back up, it did this about 4 times.
this last time it died, I pulled over started it up, drove 100 yards and it died again, and now it just cranks and cranks, I'm getting fuel to the carb. there's fuel in the line. it has a new clear fuel filter and its CLEAN as a whistle! WHAT IN THE HECK is causing this thing to die? I've eliminated any misfires, and fuel issues, its got a MECHANICAL pump so if it were bad it would've ran terribly. one thing I've read is that it could be the Ignition Control module?? any idea on how hard it is to replace? and where it is located. i have HEI ignition as well. its a late 60's 417 block but I'd assumed the ICM would be the same location as a SBC? I'm about ready to just let the damn truck sit and ROT |
03-08-2014, 02:26 AM | #2 |
Another Day, Another Dollar
Re: i have HAD IT with this truck!! still randomly dies...
Keep a spare plug in the glove box. When it dies pull a lead and check for spark with your extra plug!
Check beside the cap for your ign module
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
03-08-2014, 09:24 AM | #3 |
does it have a plugged up catalytic converter ?
mine acted like that, and it was the cat...
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
03-08-2014, 09:33 AM | #4 |
Watch out for your cornhole !
I'd bet you're losing spark. The ignition module is very likely in that situation. All it takes is a nutdriver to change it. Ten minute job tops.
03-08-2014, 10:08 AM | #5 |
The module is easy to change.
Here's a link with some good pics. http://www.popularhotrodding.com/tec.../photo_06.html |
03-08-2014, 10:23 AM | #6 |
How about a loose ground or power wire to the ignition circuit? Maybe a dying fusible link? It does sound like your spark is going away rather than being fuel related
03-08-2014, 10:39 AM | #7 |
Right turn Clyde
Don't forget the thermal paste for the new module. I'd recommend acdelco for the replacement most parts stores can test the module to see if it's failed. Sometimes it will show a false pass because the tester can not get the module hot enough.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
03-08-2014, 10:48 AM | #8 |
When I'm dealing with an intermittent no-run situation, I carry one of these in the truck with me. You can get them on the tool aisle of the auto parts store.
When it dies, quickly pop the hood and jerk a plug wire and hook up the tester. Then crank the engine and see if its got spark. About 80% of the time a no spark condition on an HEI is caused by a bad module. Like the fellow above said, get a good one. Don't buy the generic parts store cheapie. When you remove the old module, clean the little shelf where it mounts to the distributor thoroughly to remove old dried on grease. Then install the new module with the supplied grease.
03-08-2014, 11:18 AM | #9 |
Is your gas tank venting properly,I had a small moon tank and it would die when is was full of gas until I put a bigger vent on it,just a thought
03-08-2014, 11:33 AM | #10 |
This happened to me. Truck would die at random times, but would always start right back up. I had replaced all of the metal fuel lines and still had a rubber cap on the vent line. I hooked up the vent line to the charcoal canister tank and it stopped dying.
03-08-2014, 12:03 PM | #11 |
laying low
Ah so familiar. I had the same happen to 85 blazer i had. I put up with it for a year or so until i found the problem. There was a broke wire in that 4wire group from the module where it runs through the side of the dist housing. The wire insulation was fine but the wire was broken inside. I moved the harness then it started. To be sure i moved the harness back and sure enough it would not start. I robbed a harness from an extra dist and took care of that. Those wires get brittle with age.
03-08-2014, 12:09 PM | #12 |
Also, check your Main power lead going into the HEI. Work hardened and broke the copper inside the sheathing. Looked fine, acted like an on off switch.Drove me nuts and damn near got me killed in my '86 Camino. Would just randomly turn itself on and off. Stick your test light probe in the end of the lead with the power on, wriggle the hell out of it and see if the light flickers. Also, the pickup coil can do weird things too. In my experience, the module is an all or nothing type thing, but ya never know. Check all your HEI wiring right at the plugs, using the light and wiggle method. Good luck!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
03-08-2014, 01:02 PM | #13 |
Moderator
Back in the dark ages My dad had a G20 van that did this for 8 months and finally just outright died. It drove me nuts.
Turned out that the spark was intermittently arcing through a thin point in the rotor and it finally burned a big enough hole to keep the spark from going where it belonged all the time.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
03-08-2014, 02:06 PM | #14 |
well i replaced the ICM and it seems to be running fine now, the metal backing plate actually separated from the plastic, from heat and age I'd asssume. and there was a small burn mark on the side that the metal part was supposed to be attached to.
03-08-2014, 02:07 PM | #15 |
sounds like an ignition module to me my suburban did this to me about a month ago and it finally just quit all together changed the module and it fired right up first turn of the key and been running since
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
03-08-2014, 10:21 PM | #16 |
I just went through this on a brand new HEI from msd
Put in a new a/c delco coil and all was fine.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
