Old 03-11-2014, 05:24 AM   #1
355bullet
355bullet's Avatar
serpentine system question
Going this route with the serpentine system.
Go used or new?....ac system
whats everyone's opinion?
http://www.jegs.com/p/Chevrolet-Perf...52514/10002/-1
355bullet is offline   Reply With Quote
Old 03-11-2014, 06:20 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: serpentine system question
I'd go used off a junkyard truck or van. The new kit is nice in that it gets you a new belt and water pump and a reman alternator, but that would sting me buying new pulleys and brackets when used will do just as well.
I'd bet I could buy a used setup from a junkyard, have all the parts powdercoated, buy a new water pump and reman alternator and belt and tensioner and still come out at less than half what they're asking for that new kit.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-11-2014, 11:30 AM   #3
Woogeroo
Wink Re: serpentine system question
Yer probably right... but that kit is for people who 'want it now'.
-W
Woogeroo is offline   Reply With Quote
Old 03-11-2014, 07:13 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Ditch the right side bracket. Get one off a truck. A 93?-95 truck. Truck brackets don't have provisions for a smog pump. I bought a bracket for a 94 truck. It looks so much cleaner. Smaller belt and one less pulley. The compressor is not best for A/C. I would replace it with a Saden version. There are brackets to make it fit. On used versions, be sure to get the V8 crank pulley. You can use your steering pump. Just swap pulleys. Used is a less expensive option if done right. New water pump is cheap. The alternator and compressor are the expensive parts. You can fit an AD144 alternator instead. 144 amps is better than 100 on power options. My door locks pop like crazy with 144 alternator.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 03-11-2014, 07:59 AM   #5
RandyP
Getting Old; Going Broke
RandyP's Avatar
Holy bat turds... Makes me wanna rethink my prices.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 03-11-2014, 07:58 AM   #6
JWall
Frequent Flyer
JWall's Avatar
I have the stock setup off a early to mid 90's truck as well.
Mine is the earlier design with the metal bracket instead of the aluminum one.
And don't forget you will need a reverse rotation water pump if you convert to a later model OEM system.
- Justin
1 Owner 1976 SWB
Old 07-10-2014, 11:27 PM   #7
bark
Nice set up, I'm doing the same, just not as pretty, what condensor you using? Mine is all LH discharge and I want to switch it to Rh to clean it up.
Attachment 1226192
Attachment 1226193
bark is offline   Reply With Quote
Old 03-11-2014, 09:13 AM   #8
gchemist
gchemist's Avatar
OH, yea. You have to find a way to support the water hose!! It's long!! I had a bracket maded to hold up mine. JWall routed his behind the alternator.
Old 03-11-2014, 09:40 AM   #9
SCOTI
SCOTI's Avatar
Reverse rotation water pump... upper radiator hose brace... and.... if using a manual fan set-up, a reverse roration fan.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-11-2014, 10:40 PM   #10
Greenlee
Greenlee's Avatar
Am I supposed to have an upper radiator hose brace??? (pic of my truck above)
Greenlee is offline   Reply With Quote
Old 03-11-2014, 10:53 PM   #11
SCOTI
SCOTI's Avatar
I re-used the factory one that was there for my bbc. I would just make sure there's enough clearance @ the fan & alt blades.
If there's alot of wiggle room, I wouldn't worry. If it's tight.... I would do some sort of anchor/brace to keep the hose from shifting.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-12-2014, 12:01 AM   #12
Greenlee
Greenlee's Avatar
Thanks Scoti. I don't remember there being any kind factory brace on my parts Suburban, but I will be on the lookout for one now that I'm aware it's supposed to have it.
Old 03-11-2014, 09:42 AM   #13
Jonboy
Slots go on anything!
You can almost buy a whole Suburban on CL to rob the serpentine system off of for that price.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 03-11-2014, 10:38 PM   #14
Greenlee
Greenlee's Avatar
Yep, I bought a running 89' Suburban off Craigslist for $750 and used the Serpentine setup, wiring harness, window regulators and lots of other parts that I'm forgetting. I also ended up with an extra transmission and engine that a buddy ended up with. I got some $ back when the shell went to the scrap yard. I think the old Suburbans are the way to go when restoring these old trucks.
My compressor came from Vintage Air.
Old 03-11-2014, 09:58 AM   #15
Cherub
Cherub's Avatar
ive done this setup 3 times now and its ran me around 600 to do it.
Cherub is offline   Reply With Quote
Old 03-11-2014, 06:44 PM   #16
king-918
king-918's Avatar
600? Why?
Did I do something wrong mine was like 85 plus powder coat and water pump
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 03-11-2014, 10:36 PM   #17
SCOTI
SCOTI's Avatar
Originally Posted by king-918 View Post
600? Why?
In addition to the water pump, add in the price of a new a/c comp, alt, power steering pump, fan clutch + fan, tensioner, & belt (unless you have all that stuff conveniently lying around). I would imagine that's some of the cost difference.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-11-2014, 11:42 PM   #18
king-918
king-918's Avatar
You're right. I started with just a motor so I never thought about it
<----Christopher
Oklahoma
Old 03-11-2014, 10:35 AM   #19
DREAMER1
DREAMER1's Avatar
What kinda set up is that? Could you give us more info on it?Looks like the a/c bracket is there, but the a/c is t installed, right?
DREAMER1 is offline   Reply With Quote
Old 03-11-2014, 11:17 AM   #20
Cherub
Cherub's Avatar
correct this is the a/c bracket without the smog pump. I believe i got these off a 96 truck. My pops truck is a non a/c truck getting vintage air later on.
Old 03-11-2014, 11:31 AM   #21
TwinTurbo
TwinTurbo's Avatar
I like the 3rd gen F body stuff, there's even a simple way to run a vacuum pump where the original air pump was
TwinTurbo is offline   Reply With Quote
Old 03-11-2014, 12:23 PM   #22
school boy
school boy's Avatar
If im not mistaken, 4.3 v6's serpentine systems will work on a sbc.
school boy is offline   Reply With Quote
Old 03-11-2014, 12:54 PM   #23
SCOTI
SCOTI's Avatar
Correct. They also come with & w/o the smog pump like the 1/2 ton trucks. As mentioned, the smog pump space can be utilized for alternative pumps if desired or look for the non-smog brackets for a cleaner (my opinion ) look.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-11-2014, 01:48 PM   #24
Tx Firefighter
If you use a V6 setup on a V8, you have to find a V8 crankshaft pulley and a couple of the little support rods that go to the intake manifold are V8 specific too.
Old 03-11-2014, 02:36 PM   #25
SCOTI
SCOTI's Avatar
What was different about the crank pulleys?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
