Old member
Well I took the truck over to the local transmission place today to have the new wiring connector installed and service the transmission. The connector was leaking pretty bad.
Guy comes back in the office and said I need to come look at something. Oh great now what. My week hasn't gone so well guys on anything and now this, it just got worse! Anyway back to the transmission. The drive shaft is only up in the transmission 2", yes thats right 2". The bushing is shot at the tail of the transmission and they think the one inside the transmission is shot to. So we take the pan off and it's full of bronze are brass whatever it's made out of. Then we inspect the yoke that Hawks installed and it's got wear marks and gouges all over it. Not a new one like he said. So the transmission people want $600.00 to $800.00 to do it and I said put it back and I'm going to Hawks now. I get to Hawks and have to wait about 20 minutes for Bruce to get there. I tell him everything that we found at the transmission shop and he says I will take care of it. So the truck is at his place waiting to have the transmission and drive shaft redone. The drive shaft is about 2 1/2" to short for the truck, so I had to take him my other shaft that he has to cut and fix. I'm not a really happy person tonight. I was suppose to drive it to Myrtle Beach next week for the car show! ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
meowMEOWmeowMEOW
Re: Major Setback
On a lift with the rear end drooped the shaft won't go ALL the way in, but still, having the shaft setup wrong really sucks.
Did they surmize the actual cause of events? I.e., are we assuming that the DS being too short put load too far out on the output shat, and that made the shaft wear the bearings out? I'm curious what the actual cause of failure was. I would be pretty leery of the shop now, if you feel like they short-changed you on the parts. Have them fix it right, or take it to another shop and send them the bill.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#3 | |
Old member
Re: Major Setback
Transmission place said it was so far on the end of the transmission shaft that it was causing the bushings to prematurely wear. Bruce said the shaft moves up and down like that and it should be fine. This is how it sits on the lift. ![]()
Re: Major Setback
That pic is sitting on the ground? You would be lucky if there is 2" in the trans!!! I can't believe you didn't have a bad vibration. Like BR3W said, I would be leary of them for letting that leave the shop like that.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#5 | |
Old member
![]() Quote:
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Major Setback
Do you have a 2-piece driveshaft in the truck?
It's alsways something.....
![]() Join Date: Nov 2008
Re: Major Setback
Good Luck Andy. Driveshafts are a a PIA sometimes. It's refreshing to see people who are willing to take responsibility and work to make things right. Hope you get it going soon. Chuck
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
![]() Join Date: Aug 2004
Re: Major Setback
Andy,
I know it is hard to take it back to the guy who did subpar work, but I agree with you. Give him the opportunity to make it right, then have someone check it just for mind's sake. I would do the exact same thing and have. I wish you luck my friend.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: Major Setback
Andy,
This is why I like to do the work on my cars and trucks myself. Even though it takes alot longer, I know whats been done, what needs modifying, and that no shortcuts were taken. Imagine the damage it could have done had the driveshaft came out. I can't tune an ECM or see what numbers I can pull on a dyno and would have to pay to have that done but I can do pretty much do any of the mechanicals of such a swap. Not putting anyone or any business down but for what you paid him there should be no mistakes. Bryan
1980 Malibu Classic 2 dr coupe 1964 Impala SS 4 speed 1968 GMC (major project) grandpa bought new 1969 Chevrolet C-10 Shortbed Fleetside 2008 GMC Canyon (daily driver) |
![]() Join Date: Jun 2012
Re: Major Setback
If they would leave an important piece of the drive train like that you can see it would make me wonder about all of the stuff they did that you can't see! I hope that they get it right for you.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
Re: Major Setback
mistakes happen. give him the opportunity to make it right and hold him to his word.
Re: Major Setback
but i guess you are vindicated about being OCD on the trans temp sensor
Old member
Well to answer all the questions.
lolife99, Yes I have a 2 peice shaft. I'm giving him the first shot which is his thrid time. He didn't balance the shaft the first time after cutting and welding it. Had to take it back and have it balanced. I really don't know of anyway other than this to settle it. I was almost to the point to let the transmission people do it but after the $600-$800 estimate I said heck no Hawks needs to make this right. I just hope it's ready by next Wednesday. I'm suppose to be driving it to the beach for the big car show which is a 5 hr ride. Oh boy this should be fun. I was going down Wednesday night after work but I don't know now. Being stuck on the side of the interstate at 12PM 1AM in the morning want be fun. ![]() ![]()
#14 | |
Freakin Awesome!
Re: Major Setback
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee |
#15 |
Old member
I have all that. I don't like sitting on the side of the road though waiting for them and I want leave the truck just sitting there!
#16 |
Re: Major Setback
its always good practice to give everything a once over after you've had someone wrenching or working on your stuff (anything you own for that matter), especially when life is at risk, simple thing like this could have been caught very easily. Good to hear thatthe shop is taking care of it.
i worked for a equipment rental outfit and we had hundreds of 6.0 powerstroke rentals, if you know much about them they are garbage in stock form, but f**d handled the issues under warranty. We would get multiple trucks back missing numerous bolts and parts, we once got a pickup back that had a motor replaced and they didn't even put one bell-housing bolt back in. But that would have never been caught without a once-over. |
#17 |
![]() Join Date: Sep 2005
Re: Major Setback
if there was brass and brozen in the pan the trans needs to be rebuilt.
#18 | |
Old member
![]() Quote:
#19 |
Old member
Hawks left me a message yesterday. They say the truck is ready to pick up!
Huh...less than 3 days and it's ready to go. I'm getting off work at Lunch time to go see about it. ![]() ![]()
#20 |
Re: Major Setback
crawl under and look at the drive shaft and make sure you got a good bit into the trans
#21 |
Re: Major Setback
As mentioned always take it back to the place that worked on it last. I work at a performance shop myself and it burns my hide when someone has an issue but doesn't return and give us the chance to make it right.
#22 |
Old member
Re: Major Setback
Well I picked up the truck today. I was surprised this morning after talking to Bruce. He had Carolina Driveline do a one peice drive shaft for the truck at his expense not mine. $490.00 and it looks great!
The transmission he said was fine other than the rear tail section bushing and seal. They replaced it and he flushed the trans out good 2 times he said. Changed filters each time and said it was good to go. He gave me a 30 day garuntee with it. I would like to have had it rebuilt but with the 30 days I'm Ok with it. We will see how it does. Driving to the beach next week so that should be a good test for it. 5hrs each way running 70-80 all the way. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#23 |
Re: Major Setback
Wait a minute. You took this in and they first-cut the shaft too short-Second, did not balance it,-third , removed it and balanced it and then reinstalled the then too short shaft without making it the right length. And then only when you brought it to their attention they are going to fix it. Makes you wonder if they really rebuilt your trans in three days and how well it was done, if it was actually done. HMMM
I am with Byran H on this one. For your sake, I hope they really fix it.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#24 | |
Re: Major Setback
Wow guess I should have read the whole thread. If that is true then id be looking for a new shop. Good luck with it!!! |
#25 | |
![]() Join Date: Oct 2013
Re: Major Setback
