03-11-2014, 10:41 PM | #1 |
steering box/pump fitting size?
does anyone know what fittings I would need to convert the power steering hoses over to -6an braided hose?....what thread size? are they metric?...86c10.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
04-07-2014, 05:12 PM | #2 |
Re: steering box/pump fitting size?
fyi...
04-07-2014, 06:20 PM | #3 |
My 89 used Metric o-ring style fittings. If that's what yours has, I can get the sizes @ my shop.
04-07-2014, 06:43 PM | #4 |
thanks...but I already got them, ones 18mm to -6an and the other two are 16mm to -6an. the fuel line quick connect I have will work on the pump side return line.
04-13-2014, 10:49 PM | #5 |
done...
05-04-2020, 07:15 PM | #6 |
Called Summit and told them what I needed and for what truck (1972 C10) power steering gear box 9Pressure side) and they sent me Russell 648030???
Are one or both (648060-648080) for a 72 C10? TKX |
04-17-2014, 02:36 PM | #7 |
thats super clean
04-17-2014, 07:50 PM | #8 |
04-18-2014, 08:57 AM | #9 |
Is that a standard AN hose on the pressure side? You'll need a high pressure hose assembly instead of the standard type that you would use for fuel. It won't handle the 1,500-2,000 psi of the power steering system. The return side is ok with that, as it is the low pressure side. Russell offers some components specifically for p.s., as do others. Just thought I'd check...
04-18-2014, 09:40 AM | #10 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-18-2014, 03:12 PM | #11 |
Depending on which brand you would like to go with, here are a few examples;
Russell Powerflex Hose: Stainless Braided Hose for High Pressure Power Steering Lines, Teflon inner liner, 308 stainless steel braid, -6 size, 2,500 max psi, 3' length, Part # 632600, use with Powerflex Endura Hose Ends. Aeroquip AQP High Pressure Hose: Abrasion resistant fabric cover for long life, available in black or blue, Synthetic rubber inner tube, -6 size 2,250 max psi, 3' long only available in black, part # 1503-6-3, 6' long blue part # FCG0606 Earls Power Steering Hose: Abrasion resistant fabric cover, pretty much the same as the Aeroquip with ratings, I think they are both made by Parker, available in blue, 6' long part # 130606ERL. Be sure to use the corresponding hose ends specific to each manufacture. We use the Aeroquip hose and Ends, but have also used the Russell Stainless braided. Depends on the look you are going for. I'll get a pic of the hose posted this evening. Fragola also makes a power steering hose, available in blue similar to Earls and Aeroquip. We can |
09-01-2020, 12:29 PM | #12 |
Moderator
I believe the fitting sizes are:
11/16"-18 for pressure 5/8"-18 for return
