![]() Join Date: Apr 2012
Orig white steel wheel paint code
Does anyone know what color white was used on the six lug four nubs?
CAN'T FIX NOTHIN
Re: Orig white steel wheel paint code
I dont have any tech lists with those paint codes on them but GM had a white they used for everything it was code 11 GM I bet thats what they are ,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
CAN'T FIX NOTHIN
Did a quick search and look down thru this list of white the used the code 11 a lot !
http://paintref.com/cgi-bin/paintdet...?gmcode=WA3967
![]() Join Date: Jun 2012
And they just changed the name of it huh....
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
There is also a code 12 white that was used a lot on these trucks ...
http://paintref.com/cgi-bin/paintdet...?gmcode=WA5111 |
IIRC it is the same GM 521 (Ditzler 2185) white as on the roof, bumpers, wheels and tailgate letters. Of course this also depends on the year too. A lot of earlier trucks used off white trim on trucks with other than white body color paint.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
I have a radical idea!
My '68 has everything trimmed in 526 Ivory.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
You mean like this (68 data book, as revised February 1 1968)?
Of course to be correct your '68 should have silver wheels not ivory.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 03-13-2014 at 09:03 PM. |
Both 68 front ends that have been on my 68 had silver front ends, the grill and fender ends. Both were original paint.
The silver to ivory grill was a running change in 68. Since the the specs I posted were marked as a change in the data book that may have been the general announcement date. I am not sure of the actual change over date if there is one much less at a specific plant or serial number. So early trucks were silver (see brochures) late 68 were ivory to generalize.
My truck came with chrome hub caps, and the wheels have never been silver. I have scraped them down to the metal under the hubcap and the factory paint on the wheels is white. I also know of another '68 that is a factory paint truck that has white wheels. This truck spent its whole life in totally stock form owned by the same family since new. Both my truck and that truck also had white grilles. I don't know the build date of that truck, but mine is March of '68, so it is a later built '68. I know all trucks in '68 that got painted caps got silver wheels, but I am convinced some of the later trucks got white wheels with chrome caps. I've seen several 50th anniversary trucks were said to be original paint trucks with white wheels and chrome caps also.
Im sry, i forgot to specify that im looking for the color used in 1972.
GM 521 (Ditzler 2185) white, same color as the white trucks or two-tone parts were 70-72
does anyone know what the backspacing of the 6 lug 15x6 4 nub wheel should be? and if it differs from front to rear?
