Old 03-13-2014, 10:48 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
Need 8" lift pics
Starting a new project
Shortbed, one tons w/ 4.56, 6.0/4l80e (case???), frame up build
Thinking of putting a 8" lift on it and running somewhere around 37's to 40's
Would like some pics
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 03-14-2014, 07:32 AM   #2
ryanroo
ryanroo's Avatar
Re: Need 8" lift pics
if you open up my profile, the picture is my longbed on an 8" and 40s. i may have more, but i headed to work, so ill have to dig them up later
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-14-2014, 08:46 AM   #3
jamesjones
Freakin Awesome!
jamesjones's Avatar
To each his own, but I wouldn't go that big w/ that drivetrain. The 6.0 has some good torque but judging by the other rides in your sig, you may not be happy with the power turning that setup.
I have 37's on my '06 CTD Megacab Dodge and it was a noticeable difference.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 03-14-2014, 09:34 AM   #4
6600DURAMAX
I am a little concerned about the lack of power might go with a 37". I am really wanting this build to be a driver. Something we can jump in and drive it 100 miles or so and not worry about it but still be show truck. Will probably go thru the motor and install a cam so I can get about 400 hp out of it. It's still early in the process. I wil change my mind at least a few hundred times. Input always welcome guys. Thanks.
Old 03-14-2014, 07:15 PM   #5
86454k30
86454k30's Avatar
The K30 has 10" superlift with 38x14.50R16's KM2's on 16x10's. Actually......this one has 10" front springs, 6" rear springs with a 2" block. So the rear is only 8"
The shortbed I found online has a 8" with 37's
86454k30 is offline   Reply With Quote
Old 03-14-2014, 10:35 PM   #6
6600DURAMAX
Nice trucks. Really want pics of 67-72 though. Maybe I should decide on the exact tire wheel combo then fit the lift around that
Probably should find a frame first. Hahaha
Already have one tons and a 6.0 LS
Old 03-15-2014, 05:45 PM   #7
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
My 68, but I only 4" with 37s as I like them nice and stable. Plus, it fits in a 7' garage door with ease.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 08-10-2014, 03:04 AM   #8
Mudd_rock_17
does it rub much?
Mudd_rock_17 is offline   Reply With Quote
Old 08-10-2014, 09:24 AM   #9
russgt
russgt's Avatar
4 inch rear springs with a 4" shackle flip, 6" front springs with extended shackles, roughly about 8" all around. 40" ground hawgs on 1 tons.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 08-10-2014, 09:53 PM   #10
lowrollin70gmc
Too many projects
They didn't rub once I got everything setup the way I like.
I did have to slightly trim the front of the rear wheel wells (round the corner, maybe 1") and the fender cups up front are close but don't rub. All my flex comes from the rear axle, my front is pretty stiff due to supporting the Cummins.
I run 35" Duratracs in the winter (the Baja T/As suck on ice) and I ended up selling the surplus Baja T/A 37s on steelies last winter to insulate and finish my garage. I do plan on a new set of 37" treadwrights on 8 lug slots next spring.
Andrew
Old 03-15-2014, 11:30 PM   #11
6600DURAMAX
Nice.
Old 03-17-2014, 09:27 PM   #12
6600DURAMAX
Ttt
Old 03-18-2014, 06:58 PM   #13
blazerboy72
Mine is a blazer not a shortbed put here is a pic any way. It is 8" with 38.5's. It is being lowered to 4" and 35's.
blazerboy72 is offline   Reply With Quote
Old 03-18-2014, 11:36 PM   #14
6600DURAMAX
Thanks for the pic. If you are interested in getting rid of the springs let me know. I might have a set of 4" Pm me
Old 03-21-2014, 03:56 PM   #15
RLONG
RLONG's Avatar
This is close to 8'' with 39.5 I rocks.
RLONG is offline   Reply With Quote
Old 03-22-2014, 12:50 AM   #16
409sbc pwr
409sbc pwr's Avatar
Here's mine 8 inch all spring on 37s and 20s
84 3/4ton swap 4x4, 409sbc 37x13.50 toyos 8 inch superlift
2007 2500 HD, 10-12 cognito lift, 38x13.50 toyos soon to be boosted via rearmount system
409sbc pwr is offline   Reply With Quote
Old 03-30-2014, 11:06 AM   #17
jim harig
jim harig's Avatar
8" lift with 37x13.50. With 1" offset, still room for bigger tires.
jim harig is offline   Reply With Quote
Old 03-31-2014, 11:54 AM   #18
6600DURAMAX
Very nice rig Jim, that is the look I want. 8'' it is
Are those 20''s
Old 03-31-2014, 12:04 PM   #19
jim harig
jim harig's Avatar
Those are 18" wheels. 15" wheels or tires are becoming a thing of the past.
Old 03-31-2014, 12:07 PM   #20
6600DURAMAX
I agree, I am running 17x12 on mine but would like to find some 18x 12 for this project. 20's can look ok but it is hit and miss in my opinion. Newer trucks OK but these old body stlye is tough. I put my 22''s on one day just to see and it looked awful. hahahaha
Old 03-31-2014, 09:36 PM   #21
7" lift with 37s
Old 04-01-2014, 12:53 AM   #22
willett
Another Day, Another Dollar
willett's Avatar
I think anything bigger than 16.5 looks out of place on an older truck.
That's just my opinion of course.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
