Old 03-14-2014, 05:43 PM   #1
muley
muley's Avatar
C 20 Tire Size
Hola,
I've got a 1969 C 20 Longhorn. The tires on it now are 245/75/16. I'm curious if anyone else runs a bigger size. I've got a 4:10 rear axle and would like to get a little better mileage if I can, but I want to make sure the fronts don't rub on turns.
Thanks if anybody can add to this.
Grandpa 1953 M38A1 Jeep
1989 GMC K2500
1958 Alaskan Camper all original
WORK : A necessary evil that finances
what I really like to do.
muley is offline   Reply With Quote
Old 03-14-2014, 06:08 PM   #2
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: C 20 Tire Size
265/75/16 will definitely work.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 03-14-2014, 06:28 PM   #3
jocko
jocko's Avatar
Re: C 20 Tire Size
Yep, what sicklajoie said. 265/75/16 Same thing I've run on my 72 - no interference, not even close. (the last pic is a member's and I'm almost certain that these are even taller - will try to see what size later on some pics I have on another computer - but I "think" they are 235/85/16s). Still wish I'd bought this old saddle custom camper...
Old 03-14-2014, 06:51 PM   #4
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: C 20 Tire Size
I believe 235/85/16 and 265/75/16 are the same height, just that the 235s are a narrower treadwidth.
Old 03-14-2014, 07:21 PM   #5
jocko
jocko's Avatar
Re: C 20 Tire Size
Excellent point, and, you Sir, are correct! I just cross-checked on the BFG site, they are within 0.2" of each other for diameter. So, just depends which aspect ratio you prefer, tall and skinny or a little wider and same diameter.
Old 03-14-2014, 07:28 PM   #6
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: C 20 Tire Size
I went from 235s to 265s on mine. I like the slightly meatier look.
Old 03-15-2014, 11:18 AM   #7
muley
muley's Avatar
Re: C 20 Tire Size
Thanks for the input! I run 235/85/16 on my Suburban, and like them just fine. My plan is to go as tall as I can to try to gear it up a bit, without interference with the steering or suspension.
1989 GMC K2500
Old 03-15-2014, 11:30 AM   #8
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: C 20 Tire Size
What you really need to do is post some pics of your truck!
Old 03-15-2014, 12:30 PM   #9
muley
muley's Avatar
Re: C 20 Tire Size
If I figured out how to do this, I'll send more.
1989 GMC K2500
Old 03-15-2014, 12:42 PM   #10
muley
muley's Avatar
Re: C 20 Tire Size
Size:  47.4 KBI need more room than here in the driveway.
1989 GMC K2500
Old 03-15-2014, 12:43 PM   #11
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: C 20 Tire Size
Nice!!!
Old 03-15-2014, 10:03 PM   #12
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: C 20 Tire Size
On my '69 C20 I'm running 285/70-17 tires with H2 Hummer wheels on all 4-corners..
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 03-15-2014, 11:14 PM   #13
1968C20CST
1968C20CST's Avatar
Re: C 20 Tire Size
The hummer wheels look nice.
1968C20CST is offline   Reply With Quote
Old 03-16-2014, 01:07 AM   #14
BlacklandCamper
Re: C 20 Tire Size
Agreed. Those look awesome.
Is that 2wd? What did you do to get yours level? That is the stance I am looking for.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline   Reply With Quote
Old 03-16-2014, 10:34 PM   #15
derotoreut
derotoreut's Avatar
Re: C 20 Tire Size
It is a 2WD C20. When I did front disc conversion I changed out the front springs. I installed some HD springs (P/N 2772074) bought from NAPA. Tires do not rub at all. They are 285/70-17 tires with H2 Hummer wheels. The ride is a bit stiff, but hey it's a 3/4 ton truck. I never did anything with the rear springs (yet). Here's a comparison of the springs:
The stock HD C20 springs are as follows:
http://www.napaonline.com/Catalog/Ca...752_0162319756
Part No.: 2771752
No. of Coils: 7.92
Free Height: 12.94"
Spring ID: 3.68"
Spring Load Height: 10"
Design Load: 2950
Spring Rate: 1016
Wire Diameter: 0.812"
The springs I put on from C10, C20, C30 from 1973-83. They are as follows:
http://www.napaonline.com/Catalog/Ca...074_0162301536
Part No.: 2772074
No. of Coils: 8
Free Height: 13.61"
Spring ID: 3.676"
Design Load: 3841
Spring Rate: 1060
Wire Diameter: 0.83"
You could also use C30 mid '80's 1-ton springs, but I thought they would be too stiff. Those are:
http://www.napaonline.com/Catalog/Ca...085_0162304063
Part No.: 2773085
No. of Coils: 7.93
Free Height: 13.34"
Spring ID: 3.65"
Spring Load Height: 11"
Design Load: 3289
Spring Rate: 1318
Wire Diameter: 0.906"
~ Dan
Old 03-16-2014, 07:34 AM   #16
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: C 20 Tire Size
I think he put 73-87 springs in the front to level it out.
Old 03-16-2014, 11:47 AM   #17
BlacklandCamper
Re: C 20 Tire Size
I thought that might be the case. I really need to do that to my 71.
Old 03-16-2014, 11:45 PM   #18
BlacklandCamper
Re: C 20 Tire Size
I was thinking along the same lines, but I wouldn't mind a little stiff. The stock spring replacements I list at work are...
Free: 12.94
Installed: 10
Load: 2950
Rate: 1016
Moog part # 6104
The springs I thought of are off of a 1988 R30, there are three versions, standard, with R42 suspension, and R42 HD suspension.
I was going to use the R42 HD option.
Free: 13.59
Installed: 11
Load: 3788
Rate: 1464
Moog part # 6560S
The R42 springs are,
Free: 13.19
Installed: 11
Load: 3289
Rate: 1501
Moog part # 6560
I am looking forward to both seeing how my truck looks leveled out, and driving it. My stock springs are REALLY worn out. The PO already put wedge spacers in them, and they still sag.
/hijack
Old 03-17-2014, 09:07 AM   #19
derotoreut
derotoreut's Avatar
Re: C 20 Tire Size
Keep us posted. I can't wait to hear how it works out for you. Like to see pictures for sure!
~ Dan
Old 03-18-2014, 01:53 PM   #20
72MARIO
72MARIO's Avatar
Re: C 20 Tire Size
I had 285 75 16 on 16x8 rims and they rubbed the front bottom of the front fender. I have a 3" fabtech lift coil. I swapped them out to 265 75 16. with the bigger tires my ball joints and idler arm hated me. Under 35000 miles and they were toast.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
