Old 03-15-2014, 03:00 PM   #1
kelsfine69
18 Till I Die
kelsfine69's Avatar
Can a tranny knock like an engine on start-up?
87 Silverado 350/700R4. Every morning when I go to work something is knocking like an engine rod knock. Thats exactly what it sounds like and then after about 5 seconds its gone and doesn't return till next morning on first start-up. I thought ok drive it till it craters then drop in a new crate engine. But it wont die. 2 years and counting. If it was a rod bearing it would of packed it in long ago? I'm now starting to think its the tranny?. Its really hard to hear where its coming from, but its loud. I have a vibration as well that has always been there since I bought it. I believe its the torque converter so Im thinking about getting the tranny rebuilt and see if thats it. They did have problems with vibrations due to torque converters back in the 80's..
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 03-15-2014, 03:39 PM   #2
IdahoStepside
Re: Can a tranny knock like an engine on start-up?
Cracked flex plate?
IdahoStepside is offline   Reply With Quote
Old 03-15-2014, 03:42 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
sounds like the flex plate if its not the motor
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-15-2014, 03:52 PM   #4
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Take the inspection cover off the transmission and remove the torque convert bolts. That will help isolate the transmission from the engine noise. It will also allow a better view of the flexplate to check for stress fractures.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 03-15-2014, 04:47 PM   #5
kelsfine69
18 Till I Die
kelsfine69's Avatar
Only once a day first thing in the morning? If it was a flex plate wouldn't it do it on every start-up? I know I should roll under and take the cover off. Cold makes it worse.
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 03-15-2014, 05:33 PM   #6
geezer#99
geezer#99's Avatar
Could be detonation.
Easy to check, just pull the vac hose off the vac pot on the distributor and plug the hose (a golf tee works).
Less messy too!
Old 03-15-2014, 09:18 PM   #7
Dead Parrot
Had a noise like that start up a few weeks after installing a new crate motor. Turned out to be the power steering pump.
Dead Parrot is offline   Reply With Quote
Old 03-16-2014, 12:53 AM   #8
Krwright
Unbolt torque and slide it back then fire it up the next mourning.
i do my burn outs in 4wd
Krwright is offline   Reply With Quote
Old 03-16-2014, 03:13 AM   #9
kjc292
kjc292's Avatar
I've experienced the same issue but with a different vehicle. Its a 95 bronco. the oil pressure started reading high then i noticed the knock at start up. started out loud then quieted down after 4-6 knocks. and yes it was only in the morning(after all the oil drained down back to the pan....) I changed spark plugs and oil. went with a 10w-40 instead of 10w-30. the knock stop instantly, but a few days later oil pressure started reading high again... still no knock. only thing i could think of is the oil pump could be taking a little to long to get the oil to top and down. reason i say that is switching to a heavier oil helped instantly, keep in the upper block longer.
79' c20 std cab 292 3speed granny - daily driver.
77' c30 std cab 454 th400 4.10 - fathers truck then mine.
95' ford bronco 302 4speed overdrive.
2002 mustang auto v6 - girlfriends daily driver.
Debt just means that you had more fun than you're suppose to have
kjc292 is offline   Reply With Quote
Old 03-16-2014, 09:37 AM   #10
Katrina/10
Katrina/10's Avatar
Piston slap. After they warm up and expand, it goes away till the next day.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
