Old 03-15-2014, 06:43 PM   #1
bloibl
looking for some help with parts
Can anyone tell me where I can get some custom and not custom parts
1. looking for a mid height transmission tunnel 67-72 (does this exist)
2. Does someone make a custom rear fender wells that will fit a 12 inch wheel
Thanks in advance
bloibl is offline   Reply With Quote
Old 03-15-2014, 08:27 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: looking for some help with parts
Thanks in advance
1. The only transmission tunnels are high hump and low hump....
2. Not to my knowledge, you will have to widen them. Easiest way is to get a second set and cut both halves wide enough so you only have one weld line on each side. You can also cut yours in half and add a strip in the middle.
LockDoc
Leon
Old 03-15-2014, 08:50 PM   #3
Hatzman
Hatzman's Avatar
Here are some pics of what I did with my wheel wells... I can fit a 14 inch tire with ease. I added 4 1/4 inch additional piece of a stock wheel well to my original.
If you notice, the stock design was kept throughout, so it looks stock if you didn't know it was wider.
You can see the weld there underneath...
Hope that helps you...
Steve
___________________________________
http://67-72chevytrucks.com/vboard/s...d.php?t=618848
Hatzman is offline   Reply With Quote
Old 03-15-2014, 08:52 PM   #4
Hatzman
Hatzman's Avatar
P.S. I am using a 79 Cadillac Seville rear end, which is quit a bit shorter than stock. (don't know if that makes a difference other than with backspacing issues.)
Steve
Old 03-15-2014, 09:05 PM   #5
Tinkermc
yes sir split that baby wide open and add some material, don't forget the contours.
Tinkermc is offline   Reply With Quote
Old 03-15-2014, 09:27 PM   #6
vidman
vidman's Avatar
Yep, take 4 and make 2 big ones.
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 03-15-2014, 09:37 PM   #7
Hatzman
Hatzman's Avatar
Very nice Vidman.
Steve
