03-16-2014, 03:19 PM | #1 |
Rear lowering springs?
Do you need a adjustable panhard bar with 3" drop springs? I made some 2" lowering blocks and got longer U bolts so now I want to do 3" drop springs to = 5" of drop.
Also would my shocks still work or do I need different ones? Thanks |
03-16-2014, 09:52 PM | #2 |
Re: Rear lowering springs?
Anyone?
03-17-2014, 08:36 AM | #3 |
Watch out for your cornhole !
You will need an adjustable track bar of some flavor. That 5 inch drop is gonna shift the rearend to the side a noticeable amount.
03-17-2014, 10:38 AM | #4 | |
Thanks TJ |
03-18-2014, 06:45 AM | #5 |
I'd go with the 5" spring.
Reason why, a 5" spring costs the same as a 3" spring. And, in the future it gives you the option to add a 1 or 2 inch block if you decide you want to go down further.
03-18-2014, 10:36 AM | #6 |
03-18-2014, 08:00 AM | #7 |
Bag it!
If you ever want to tow something other than a small lawn mower trailer, bag it! the 3+" lowering springs are rather light duty and wont support much weight on the hitch or in the bed.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
