03-16-2014, 07:07 PM | #1 |
Best deal on front lowering spindles
So far the best i can find is at summit racing $229.00 and free shipping
Part cpp-cp-4s3 2.5 in lowering correct? But my question is cp4s3 the old style or new that moves in 3/4" to allow for wider tires? i want to keep my 255/60/15 on the front. I also want to stay 6 lug front disk and the best deal is $89.00 part #03-6370-6l at ECE or CPP. Any better deals out there? Last edited by 67stepper; 03-16-2014 at 07:13 PM. |
03-19-2014, 07:40 AM | #2 |
67-72 parts collector,…
Re: Best deal on front lowering spindles
I don't think it's ever been proven how much the CPP Modular spindles move the wheels in.
Never could get an answer to this question when CPP had a Vendor on here. Plus,... moved in compared to what? 1) drum brakes? 2) stock disc brakes? (which we know are 3/4" wider than drum brakes) 3) other manufacturer's drop spindles? Just saying,... don't count on the 3/4" measurement you mentioned in your post.
03-19-2014, 04:39 PM | #3 |
Just order a set from CPP ebay store $215.00
67 longbed fleetside switching to a 67 shortbed stepside with a 71 front clip, front disks, 2.5" lowering spindles w/1" lowering spring in the front, 5" lowering spings w/1" lowering block rear, 255/6015 front and 275/60/15 rear on 15x8.5 slotted mags, 355/350, 12 bolt 4.11 posi. |
03-20-2014, 08:28 PM | #4 | |
1967 swb 454 cid 700R4 trans SOLD 2006 Chevy Trailblazer SS 2013 Camaro RS convertible the wife's Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248 |
03-20-2014, 01:18 AM | #5 |
If I'm not mistaken, the "newer" style CPP modular spindles are only 2" drop and also require a bracket not included with the spindle depending on which brake caliper you chose.
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
03-20-2014, 01:31 AM | #6 | |
VA72C10
These are a new version that is supposed to be 2 1/2" drop. They don't look like the modular ones I've had that required a separate bracket...these look to fit factory calipers like the mcgaughy spindles I had... Says on the ad it
The ones I linked use 73-87 ball joints/tie rods which I usually recommend as they are easier to source and generally cheaper. |
