03-16-2014, 07:13 PM | #1 |
Engine Oil and type?
How many quarts does the 5.3 truck hold with a filter.
I heard that the only filter to use was a A/C, because of some internal valving, is that true? What weight oil is everyone using
03-16-2014, 07:27 PM | #2 |
Re: Engine Oil and type?
6 at 5w30 anything but from I use puraltor wix acdelo k&n Mobil 1 there all good
03-16-2014, 07:36 PM | #3 | |
meowMEOWmeowMEOW
It helps with dry starts, and iirc it also helps with vehicles that have the filter mounted in a way that can cause the filter to run dry (Remotes). This was something that I remember getting brought up as an issue on older high performance motors, but I'm not sure if on todays engines running synthetic oil it even matters much. A/c isn't the only one, as WIX and others have also used it for a while. Certain part #'s don't have it, as certain vehicles don't benefit from it. I try to avoid any super-cheapie filters, but I've used WIX, A/C, the Royal Purple brand, and a few others. There used to be big problems with fram, not sure how they are now.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
03-16-2014, 08:35 PM | #4 |
6 quarts for a truck pan, Gen III truck engines take an AC PF46, All crosses to this filter have a Anti Drain Back Valve. 5W30 is the oil spec.
03-16-2014, 10:17 PM | #5 |
Thanks guys, I must have the wrong indicator stick as I think I put 7 qts before it registered, and I did put in a Wix.
I guess I will change filters that should take care of most of it !
03-17-2014, 11:38 AM | #6 |
Make sure the oil dipstick AND tube match the oil pan that you are using! Seems like each model is a little bit different and can give incorrect oil indications.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-17-2014, 03:03 PM | #7 |
Great, TBSS headers and a truck oil pan on a 5.3, the truck tube did not fit the headers, so I will try something different
03-17-2014, 04:12 PM | #8 |
meowMEOWmeowMEOW
You sure? The truck tube will fit, just don't bolt to to the head right away. Let it sag towards the next cylinder a little for clearance, and you can just tac a new bracket on.
03-17-2014, 04:14 PM | #9 |
I used tbss manifolds and the stock truck dip stick and tube fit
03-17-2014, 04:27 PM | #10 |
It will not work IF YOU bend it too far, and then try and straighten it out !!!!!!
