Old 03-19-2014, 10:45 PM   #1
Mikeh8
Brothers aluminum under bed gas tank
Has anyone mounted one of his ATK 6372 side fill tanks ? If so what did you have to cut and did it give you more or less ground clearance ? Did it bolt right to the frame or does it use straps like the stock one?Thank you any help will be great
Mikeh8 is offline   Reply With Quote
Old 03-20-2014, 09:12 PM   #2
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: Brothers aluminum under bed gas tank
Originally Posted by mikeh8 View Post
has anyone mounted one of his atk 6372 side fill tanks ? If so what did you have to cut and did it give you more or less ground clearance ? Did it bolt right to the frame or does it use straps like the stock one?thank you any help will be great
ttt
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
