03-22-2014, 08:58 AM | #1 |
Headlights
Headlights wont turn off... I have to unplug lamp to turn off...when i plug them back in at night to use lights high beams are on and wont turn off from floor switch
03-22-2014, 09:51 AM | #2 |
Re: Headlights
I would suspect the foot switch. Unless you've been doing some wiring lately. Try disconnecting the foot switch and see what difference it makes. Something is bypassing the switches. Either you have a short between wires or a switch has failed. Once you figure it out, I would recommend getting a headlight relay. It takes the load off of the switches.
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
03-22-2014, 10:03 AM | #3 |
Easy Does It
Re: Headlights
were they working fine before, did you change anything in the wiring right before this happened?? maybe the headlight switch has gone bad-do all the lights stay on or just headlights? see if the dimmer switch is stuck- does it push in and out. sometimes bad grounds make weird things happen, make sure the ground wires have good contact. im sure others on here will be able to help you out.
03-22-2014, 08:02 PM | #4 |
Re: Headlights
Did you ever test your switch?
Have you really been dealing with this for two months? http://67-72chevytrucks.com/vboard/s...d.php?t=612318 Next time just build on you old post if it is the same problem, it keeps things clear for everyone.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
