Old 03-22-2014, 01:09 PM   #1
silentt
Need help replacing window regulator
I'm trying to replace the drivers side window regulator now in my 1971 c10. I've read a bunch of threads but all of them instructed to lower the window first to start. My window is stuck all the way up. What would be the best way to go forward? My door panel is off ready to go
Any help would be appreciated. I hate not having a driver window that rolls down
silentt is offline   Reply With Quote
Old 03-22-2014, 01:18 PM   #2
Molberg
Molberg's Avatar
Re: Need help replacing window regulator
The track at lower edge of glass has notches where the nylon wheels of regulator have to pop out. Try pulling down on cross arms and cranking handle at same time to wiggle it down to required height
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 03-22-2014, 01:19 PM   #3
Molberg
Molberg's Avatar
Cross arms of regulator I mean
-Project Nitemare-
Old 03-22-2014, 01:41 PM   #4
silentt
This window is jammed shut like the previous owner never wanted it to open.
The part that the window handle pops on to just spins freely without engaging the teeth. I can't get anything to budge, the window has no play at all.
Old 03-23-2014, 09:10 AM   #5
Daddy Brim
Daddy Brim's Avatar
Put a vice grip were the handle goes, use generous amounts of your favorite penetrating oil. Look and see if you can find were it is binding. Turn regulator and pull down on glass.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 03-22-2014, 01:44 PM   #6
Molberg
Molberg's Avatar
You could cut the cross arms of the regulator and remove a piece at a time. It's garbage anyways
-Project Nitemare-
Old 03-23-2014, 11:56 AM   #7
kcsa75
kcsa75's Avatar
If the handle just spins you're going to have to replace regulator.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 03-23-2014, 03:52 PM   #8
WIDESIDE72
WIDESIDE72's Avatar
On a stuck window I believe you can take all the screws out that hold the regulator to the door till it all comes loose. Then you can figure out what has got it stuck.
WIDESIDE72 is offline   Reply With Quote
Old 03-26-2014, 07:16 PM   #9
silentt
I'll try more Saturday on my day off. All the screws for the regulator are already out. I tried the vice grips where the window knob goes but this regulator is screwed. I'm going to spray everything with penetrating oil and hopefully not break the window in frustration.
