Old 03-23-2014, 12:23 AM   #1
Calebs67stepside
Need feedback on wheel and tire combo
My Dad and I are building a 67 step side. It has 2 1/2" drop spindles with disc on the front and a 4 link 9 inch disc brake in the back. The rear is 55" WSM - WSM. We plan to run Coy C5 20x10 (5x4.5) with 3.5" BS mounted to 295/45R20. The fronts will be 20x8.5 (5x5) with 5.25" BS mounted to 255/40R20. The best we can measure is 73.5"from fender lip to lip. Your feedback will be most welcomed to advise us of any interference or better recommendations.
''IF YOU WANT MORE INCHES STROKE IT''
-Prostreet 67swb small back glass stepside 350sbc,powerglide,9in.
-65 custom small back glass fleetside 283 3sp on the column.
Calebs67stepside is offline   Reply With Quote
Old 03-23-2014, 10:16 AM   #2
suspect
suspect's Avatar
Re: Need feedback on wheel and tire combo
Just out of curiosity, why are you running 5" bolt circle front & 4 1/2" bolt circle rear? Typo?
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline   Reply With Quote
Old 03-23-2014, 10:41 AM   #3
geezer#99
geezer#99's Avatar
Use this to be accurate in your measurements.
http://www.carcraft.com/techarticles...t/viewall.html
And here's a tool that helps.
http://www.jegs.com/i/Percy%26%23039...01201/10002/-1
geezer#99 is online now   Reply With Quote
Old 03-23-2014, 11:19 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I assume you have mini-tubbed the bedsides?
I like a 295/40-20 better.
Those stepside fenders are really tiny.
Keith
Convert to disc brakes.
Old 03-23-2014, 11:24 AM   #5
lolife99
lolife99's Avatar
Your rear wheels will have 7.5" on the front side of each wheel.
(7.5" x 2 = 15" total)
Rearend 55" + 15" = 70" total width
73.5 - 70 =3.5" total
3.5" divided by 2 = 1.75" clearance to the fender lip.
You may have to run a 1" spacer to bring the wheels out a little.
Just my opinion on your numbers,...
Keith
Old 03-24-2014, 10:11 PM   #6
Calebs67stepside
Suspect - we have a 9 inch that has a 5x4.5 bolt pattern.
Thank you for the feed back. Does anyone have pics with coy wheels on their rides with tire sizes and drops?
67 c10, 67 step side, coy, wheel back spacing
