Raise my transmission
Hi, I have been searching threads on this and havent found what I need,
I have a 292 with stock 4 sp manual trans, Ive Sectioned the crossmember 1.5, shaved the trailing arm crossmember, installed disk brakes and tube control arms. The next thing that drags is the back of my transmission so I need to raise it, I was wondering if someone could suggest some other words to search for results or direct me to a thread that has info on this, Im not seeing any aftermarket transmission crosmembers that I can bolt my 4 speed to either, Any suggestions>? Ive searched Raise my transmission Transmission crosmember so far, Thanks in advance for any replys,
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
Re: Raise my transmission
Use a spacer between the cm and the trans and add a similar amount to the engine mounts or cut the rivets on the cm and lift the entire cm along with lifting the engine mounts or fab your own cm. With a protractor/ angle finder at the tailshaft make sure you are at 3 degrees downward and adjust/lift the mounts accordingly. Don't forget to watch the floor hump clearance, dizzy clearance etc. And make sure your rear diff is within 2 to 3 degrees of the tailshaft for no vibes.
GOD BLESS AMERICA! |
10 years later I'm back, truck is back together, I'm down to just putting u joints in my steering rod.
Ty for all the info. I just made a new Trans mount. Pics soon
Active Member
![]() Join Date: Jan 2021
Way to stay with it, 10 years goes by before we know it on these projects!
-Pickman (Mike) 1964 C10 Fleetside LWB “George” 1963 C50 “Green Machine” 2019 Silverado 2500HD My story (Welcome Page) |
![]() Join Date: Dec 2009
Glad you are still with your Project.
![]() As mentioned a Spacer to raise it up would be the easy. ![]()
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
