Old 03-27-2014, 08:23 PM   #1
gramps77
window install help
Is it easier to install the window first before the vent window, or can it just as easily be done with the vent window in?
gramps77 is offline   Reply With Quote
Old 03-28-2014, 07:12 AM   #2
walkerb
walkerb's Avatar
Re: window install help
It can be done with the vent already installed. Patience is what I've learned from doing door glass install!
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 03-28-2014, 08:26 AM   #3
Greenlee
Greenlee's Avatar
I had my windows in and out several times trying to get them working correctly when I put my truck back together after paint. It's easier to take the vent window completely out and take off the outer weather strip that runs horizontally across the door. You need all the room you can get to put the little plastic rollers in the channel at the bottom of the glass. Once you get the glass loosely in place, roll it about 2/3 of the way down and install the vent window and the piece of weather strip you removed.
I'm not even sure if it's possible to put the glass in with the vent window in place. I couldn't do it.
Greenlee is offline   Reply With Quote
Old 03-28-2014, 08:37 AM   #4
Greenlee
Greenlee's Avatar
Also, put lots of tape along the top of the door to keep from scratching your new paint. I managed to scratch mine even with tape!
Old 03-28-2014, 02:55 PM   #5
gramps77
even with the tape? Man, I hope I dont jack mine up. Thanks for the replies
