Old 03-29-2014, 03:56 PM   #1
rapidride3
1973 to 87 c10 lower grill panels
I have a 76 c-10 that needs a lower grill panel. I found one in a yard on a 74' gmc truck with what appears to be a 79' front end. (the headlight bezels are 1-piece made into the parking lamps with torx screws)
It is hard to see because of the headlight bezels and lower stainless cover that goes around the lower grill panel.
Is this 79' lower panel the same as my 76? I really wanna use a G.M. part when possible. Thanks.
rapidride3 is offline   Reply With Quote
Old 03-29-2014, 04:10 PM   #2
walkerb
walkerb's Avatar
Re: 1973 to 87 c10 lower grill panels
If the lower is a 79, it is different then your 76. If your looking to use your 76 bezels then you should keep looking. Hope this helps.
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 03-29-2014, 04:40 PM   #3
rapidride3
Here are some pics from the yard. I was under the impression that it "may" be the same lower panel behinf the stainless cover?
Old 03-29-2014, 04:48 PM   #4
rapidride3
And here is my 76' lower grille panel.
Old 03-29-2014, 04:59 PM   #5
walkerb
walkerb's Avatar
So the 79 trim piece is removable?
Old 03-29-2014, 05:04 PM   #6
rapidride3
good point, I saw where it had threads coming from behind the lower panel but didn't see how to remove it???
Old 03-29-2014, 06:07 PM   #7
walkerb
walkerb's Avatar
I got one in the garage ill go look now
Old 03-29-2014, 06:10 PM   #8
walkerb
walkerb's Avatar
Its is removable. Your good. Buy it
