Old 03-30-2014, 03:34 PM   #1
Squareforceone
Squareforceone's Avatar
oil pressure switch locating
Hey i swapped the 305 in my truck for a 350 and the 350 had a block plug above the oil filter where my oil pressure switch went. i have heard that people use the port behind the intake for the oil pressure but the threads are way to small for my oil switch. Is there some sort of adapter or something i'm missing?
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 03-30-2014, 03:36 PM   #2
79Betty
79Betty's Avatar
Re: oil pressure switch locating
Behind the intake is the factory spot. Although when the back of the cam wears down it will read lower pressure than is actually there, reason why your new motor has one above the filter. Gives more realistic pressure reading.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 03-30-2014, 04:28 PM   #3
Squareforceone
The new motor has the one above the filter blocked.. i need to know how to use the one behind the distributor.. mine old sensor wouldn't thread into it.
Old 03-30-2014, 05:50 PM   #4
79Betty
79Betty's Avatar
Mine is above the block. It has 2or 3 adapters, But i have a mechanical guage now. It... Kinda works.
Old 03-31-2014, 08:15 AM   #5
Your41Plague12
Your41Plague12's Avatar
The sending unit goes behind the distributor. The oil pressure switch itself that the choke light runs through goes above the oil filter on the block. Simply undo the threaded insert on the block and screw in the switch. It will work fine.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 03-31-2014, 12:25 PM   #6
Squareforceone
haha yeah right! i tried for hours to get that damn block plug out even tried heating and spraying oil into it and put a breaker bar
Old 03-31-2014, 12:44 PM   #7
Your41Plague12
Funny, mine came right out. That's definitely where it needs to go though.
Steve
Old 04-02-2014, 11:21 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
When I switched from idiot to gauges i left it in the back of the intake
used an angle and extention to move the large sender over
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-31-2014, 08:55 AM   #9
bnoon
Yes, there are adapters you can buy. All you need is something for, if I remember correctly, 1/8th inch NPT threads to whatever threads your sender has on it. They're all over Ebay, or you can sift through your local plumbing section as a home store like Home Depot, Menards, etc.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
