![]() Join Date: Sep 2013
62 inline 6 speed ideas
I have a 62 short bed step-side c10 that I have been driving and doing some minimal work to for about a year now. It has an inline 6 with no power steering or brakes and a 3 speed column shifter. I have decided that I like the truck enough that I am going to spend serious cash on getting it redone - frame off complete body and suspension restoration (am even going to get a modern master cylinder so I do not run anyone over if a brake line goes).
Anytime I have attempted any of my projects I have scoured this site and found great advice so I will ask for your help once again. My question(s) concerns driving it on the highway. Right now I can do about 50MPH but I need a good downhill stretch or tailwind to go above that. I live on Long Island NY and I will get run over if I get on a parkway or express way doing 50. Since the truck will be apart anyhow, I am wondering what would be the best idea for getting a little more speed before it all gets reassembled. The engine has 61,000 original miles and I want to keep it (maybe go with a small block V8 in the future but for now I want to stick with what I have). So, my questions are: do I have some engine work done, or change the rear end gearing, or do the new engine now, or buy a rocket pack to install in the bed (or a combination of any or all of these ideas). As always, any and all thoughts / opinions / advice / warnings will be greatly appreciated. Thank you for reading. |
Re: 62 inline 6 speed ideas
Nice truck.
It all depends what you want. Big power? Power/reliability/economy/non traditional? Traditional/ power? Now I love the idea of a inline engine, but big power is $$$. It will be reliable but high 15 mpg max I love the 283 or 327's in this truck. Very traditional, great engine, avg mpgs, easy to get parts, easy to work on, inexpensive. Check out the thread called "the pusher". Awesome engine. The second option from above, is the best of all options, power, reliability, mpgs, but very non traditional. Do a LS 5.3 or 6.0 swap.
Build Threads: "JED" 66 GMC C1000 http://inliners.org/ubbthreads/ubbth...1857#Post61857 "Cropwell" 66 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=587639 |
60-66 Nut
By the sounds of it, I would say that your differential has the 3.90 gears. To make your truck more of a highway cruiser, you could switch over to a T5, 5 speed and/or change the rear gears to 3.38's or change the entire differential for a 12 bolt with 3.42 or 3.07 gears. Your rear tire size plays a part in the rpm's as well.
Check out Tom from 12bolt.com he is in your neck of the woods.
GOD BLESS AMERICA! |
+1
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
![]() Join Date: Mar 2013
If your 6 cylinder is stock it no doubt is a 235. Your rear gears are probably 4.11. The 3.90.1 ratio was no available in the GM 12 bolt truck axle as far as I know. 4.11, 3.73, 3.42, and 3.07 are the ones I know of. Like said a T5 swap would be a good option cause it gives you a closer ratio split...and an OD. But another very good transmission would be a Richmond 6 speed...offering 5 direct gears and a single over drive. Note..many people think that the Richmond 6 speed is a dual OD, but it isn't...5th gear is 1:1 and 6th is .83 or .76 OD give or take. Both trannys cost around the same...but will help increase performance and you could keep the stock tire size. Another good thing would be to find out your RPM's at 50 mph by getting a cheap tach and that will help tell you your gear ratio...3000 RPM at 60 with 215/75/15's is a 4.11 ratio with a non-OD trans. If your ratio is 3.90 it will drop the RPM's to about 2900 and 3.73 about 2800...pending on tire size.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
'62's had the Eaton rear ends; a smaller version of the HO-52/72 that came under 20 and 30 series trucks until '72. 3.90 was the standard ratio for them.
just put a ranger overdrive in my 64 last week. worked out good. that would be another avenue to think about. gear vendors also but twice the price
or also the borgwarner od for the 3spd |
Ooh! I think we need to see pictures of that! I'd really like to put one of those in front of the SM420 in my one ton if I can find a used one; the idea of an OD + split gears (especially 3rd high) is pretty nice.
#10 | |
this was a one ton w/sm420 & 5.13. works good as is but 4.57 may be ideal if i could find a quiet one. |
I would like to have a look if you have time to post the pics. Thanks!
Just want to thank everyone for the suggestions. Looks like I have a lot of reading to do (the pusher thread, 12bolt.com and anything I can find on borg warner 3 speed OD). Will let you know the route I decide on.
#13 | |
I'll add my thoughts. First, you must understand that I am an enthusiast of the T5 transmission. They are a very affordable upgrade and the overdrive seems to be just right for trucks that have a 6 cylinder inline. Also, getting to keep my original rear and clutch assembly will save me time and money. If you install a T5, then you would have a floor shift 5 speed and could comfortably achieve speeds of 65-70 as long as you choose the proper OD gear. A T5 is not going to hold up to abuse. Just ask boucher racing what he thinks. ![]() ![]() ![]() My website has a lot of info about the T5 if you want to read more. Or send me a PM. I'd be glad to help. Jay
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#14 | |
Yup, that damn blower keeps breaking stuff! It is the weakest link prowler.
#15 |
I've currently got a 250 w/ the stock three speed. Goes down the highway @ 65 good....although it's digging pretty hard. I need to get a tach so I can tell what I rpm's I'm turning. I snagged two borg warner ODs waiting to be rebuilt so I'm hoping that will get me down into a little better rpm range. Everyone I've talked to that have run them say I won't regret using it.
#16 | |
#17 | |
65 would be more than fast enough for me. Saw a borg warner OD that was rebuilt on ebay last week and it sold for $1500. Any thoughts on whether this was a good price? My little 235 needs some help to be able to get onto a highway without serious damage. Reading various blogs about the BG bolted onto the 235 seems to indicate I should be able to easily do 65-70, but I am not sure that people post when it does not work the way they wanted. |
#18 | |
#19 |
![]() Join Date: Jun 2006
If it were me I would do the 6 speed but instead of the tiny 235 get a 292 for a fatter amount of torque. Then down the road do a late model LS swap since you would already have the 6 speed.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
#20 |
If you currently have a 230/250/292 and you're planning on adding a small block later, the only trans I'd look into would be a '94-'97 LT1 F-body T56. All the components needed to adapt them to a inline six would work to adapt to a small block, so you'd only be buying parts once. You'd want no lower (numerically) than 4.10 gears (4.56 if you have taller tires) to make use of sixth gear. With a 29" tall tire and 4.56 gears, you'd be doing 2000 rpm at 76 mph. They're rated at 450 lb/ft so you won't tear it up either.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#21 |
So are you having gearing issues or power issues? Kinda sounds like you're talking about not having enough power. My little 250 with factory 3 speed pulls up to speed just fine, but runs out of gear around 60ish. It will go faster, but its spinning pretty quick. I would think yours would be the same.
Chris
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 |
#22 | |
I really want to leave it as a three speed (learned to drive on one), so I am thinking that if I cant fix with gears I want to get a 3 speed trans to leave it as original as possible. I will put in a tach but probably hide it under the dash somewhere, so that in the future I will have a better measurement tool. Thanks for all advice. |
#23 |
Wouldn't a 340 rear end go a long way toward helping you get down the highway without doing anything to the tranny at all? Keith may be able to offer you more insight as to what rear end would work best with your existing drive train. It's a beautiful truck you have there and it appears quite original. Whereas there is nothing wrong with newer drivetrains,.....they don't build 'em like yours anymore. I would at least shoot Keith a p.m. and ask him to run a spread sheet.
#24 | |
I cannot see any Keith in this thread (but I can miss things easily), can you give me a user name? Thanks for the advice |
#25 |
His name is Kieth. That's his username too.
